for my Tiles I need an automation to set these input_booleans to Off except for the one that is selected and should be set On.
scenario:
select Tile Opstaan, -> Input_boolean.activity_opstaan turns On, -> and all other Booleans Off.
I was hoping to be able to do this in 1 automation, and not have to write a dedicated automation for all booleans, in On and Off variants…
For this reason I made them have the same format to be able to use input_boolean.activity_{} as template?
I did of course add the On command to the script itself, but still need the Off command for all others…or would it be as simple to have these input_booleans in a group, first in sequence turn them all off, and then second in sequence, turn the desired boolean on?
opstaan_direct:
alias: Opstaan direct
sequence:
- service: input_select.select_option
entity_id: input_select.activity
option: Opstaan
- service: homeassistant.turn_off
entity_id: group.activity_select_booleans
entity_id: input_boolean.activity_opstaan
Hope you can have a look, thanks,
Marius
input_boolean:
activity_opstart:
initial: off
activity_opstaan:
initial: off
activity_aan_de_slag:
name: Aan de slag
initial: off
activity_gym:
initial: off
activity_home_theater:
initial: off
activity_selamat_makan:
initial: off
activity_uit_huis:
initial: off
activity_naar_bed:
initial: off
entities:
- entity: input_boolean.activity_opstart #script.opstart_direct
service: script.turn_on
entity_id: script.opstart_direct
image: /local/activities/opstart75.png
- entity: input_boolean.activity_opstaan # script.opstaan_direct
entity_id: script.opstart_opstaan_direct
# label: Opstaan
image: /local/activities/opstaan75.png
- entity: input_boolean.activity_aan_de_slag #script.aan_de_slag_direct
# label: Aan de slag!
image: /local/activities/aandeslag75.png
entity_id: script.opstart_aan_de_slag_direct
- entity: input_boolean.activity_uit_huis #script.uit_huis_direct
# label: Uit huis
image: /local/activities/uithuis75.png
entity_id: script.uit_huis_direct
etc.
