I have a “Get Entities” node which fetches one light and one switch.
I want both to turn on with a single call service node - but it doesn’t seem to work because they have separate domain types (Switch and Light) - so only the entity with the matching domain turns on.
Is there a way to make this work for both without having a separate call service node?
You would still have to call the function twice, once with each domain.
If you have a function in front of it then there is a node.send function you could use for that.
