M1ke
1
Hey guys,
I just connected a new lamp to ZHA. Broken down, it’s basically a single color LED strip with the following driver from Sunricher:
When I connect it to ZHA (via Conbee II) it shows up as if it was an RGB driver (color wheel, no temp slider).
Is there a way to change the Zigbee configuration of this device via ZHA or do I need to get it changed in zigpy?
Thanks in advance for any tips!!
Leon2
(Leon)
2
I am having the same issue with a Tuya LED controller, did you ever find a solution?
M1ke
3
Unfortunately, no - I opened an issue in this repo, but haven’t gotten a response yet:
maybe try doing the same for your specific device?
