Single LED and NodeMCU
I am trying to use a diffused LED (red) to indicate when my garage is open. LED on when open, closed = off. I am using a NodeMCU with ESPHome. I am really battling to get the bulb to light up like a light would. Could someone please point me in the right direction. Many thanks.
For the led first create an output.
 output:
   - platform: gpio
     pin: 2
Then to turn it on
on_...:
  then:
    - output.turn_on: gpio_led
thank you, i will try that now :slight_smile:
I managed to come right with the below code. I saw with the “output” i couldn’t turn it on and off like i switch “the only way i know how to automate it”.
So i used the below code. Thank you though as you put me on the right track.
switch:
  • platform: gpio
    pin: 5
  • platform: gpio
    pin: 14
  • platform: gpio
    pin: 13
