I have a PLC network in my house, where I control many things, also lights, bathroom fans, and so on. It is all wired and programmed locally, the system is from Technische Alternative in Austria. It is not connected to HA, Alexa, Google or such.
To save on PLC outputs, as well as to avoid rewiring the house, I need this relative simple relay, which I have not yet been able to find:
Input to the relay is just one phase and one neutral mains (230V 50Hz in this case), and output is two separate low power consumers (like lighting, fans, shutters etc).
This kind of relay is like a 4 way smart relay, but instead of a pushbutton input, the selection is made by alternating the input power. Example: Mains on, both outputs are on. If mains is switched off, then on within a set period (say, 1 second or less), only one of the outputs are ON, the other remains OFF. There could be different combinations of flicking the switch, to make different combinations of output.
Be aware that my PLC units must be able to control these, so I cannot use any smart devices with wifi, bluetooth, remote controls, Alexa, Google and all that. It must be this simple: Only flicking the supply on and off will decide which outputs are open.
I have searched many relay suppliers and could not find this version of smart relays, 4-way relays, delay relays yet. It is so simple, and has many applications, so I am sure it exists. I could build one myself, with two relays, a few resistors and capacitors, but I want a single, sealed unit, for a permanent and durable installation.
Space is somewhat limited. It does not need to be DIN gang bar standard, as long as there are proper connections for phase and neutral in and out. The relay is not going to be mounted in the main circuit board, but in a junction box close to the consumers.
So if someone can please let me know where to find such a relay.
Applications: Before you reply what is the point of this kind of relay, imagine a cable leading to outdoor lighting, but now you want to split your lights into two groups. You don’t want the cables leading to the light to be live when the lights are off, you don’t want to install extra cables, just a local junction box with a relay, which splits the light into two groups. Inside the house is a normal light switch, and simply flicking the switch on and off several times will make the relay turn on either one of the light groups, or both.
In my case, I mainly need it for extractor fans with servo motor openings. Normally, these fans start the fan AND open the louver, but I need to only open the servo louver in some cases, while the fan remains off. In other cases, I need both the fan to run and louver to open.
I just found a relay by Yacht Devices, called Smart Relay YDSR-01 . It does what I want, except it is for DC low voltage. I need exactly this function, but where both input and output is 230V AC.
Once again, I cannot use remote control operated, wifi-bluetooth-app-HA kind of relays. It must be the way I described.
Thank you
DITB
