TH1124ZB
It was first set in neviweb but I think it resetted when I restarted and added to Zha.
Where should I look for the cluster ?
TH1124ZB
OK let me check if I can find that cluster
Tonight I just added support for Calypso load controller in ZHA. For now it is in my git
GitHub - claudegel/sinope-zha: This is a custom quirks for sinope zigbee devices for testing before it is added to zha-device-handlers. It also explain how to setup those quirks in Home Assistant to use and test them before they are merged in zha-device-handlers. You can copy file switch.py into your zhaquirks directory.
Later this week Iâll send a PR to zha-device-handler.
I changed the cycle throw the interface directly.
The setpoint need to be at the minimum.
You have to hold the down button for at least 3 seconds (more like 5).
Then you change for SHT or FAN with the up button. (short for convectors and fan for long cycle fan type).
Didnât find what changed in the cluster but didnât took enough time to figure out if itâs there.
Jâai complĂ©tĂ© le support pour le Calypso dans neviweb130 et ZHA
Il me reste juste a sniffer un peu le zigbee pour voir sâil y a dâautres clusters spĂ©cifiques de SinopĂ© pour le Calypso
Pour neviweb130 voir la branche calypso-support
Hereâs what I didnât understand about the display units and brightness attributes: I thought I had to install the quirks to get them to work, because thatâs what it says on the github README. But Iâve now removed the quirk lines from configuration.yaml, and renamed the zhaquirks directory, and my code to access those attributes still works. So clearly I didnât need to install the quirks.
Perhaps the github README could include an indication of which attributes are already functional in the the latest HA release.
Thanks again for all of your work on this!
When you install the quirks in config/zhaquirks it is to get the latest version. Once a change is stable in the quirks then it is pushed to zha-device-handler and added to ZHA. But this can take many days before it show up in HA.
The quirks are there to test new devices like the Calypso before it is added to ZHA directly.
If the quirks is there ZHA will load it in place of the file from zha-device-handler.
If you remove the zhaquirks dir, then HA will load the zha quirks which are mostly the same except for the newly added featur or devices.
The readme.md file in sinope-zha is listing all the cluster that we know and are availables in ZHA.
Salut Claude,
Jâai reçu mon calypso ainsi que des interrupteurs DM2500ZB. Jâessaie dâajouter les quirks mais sans succĂšs.
Selon la documentation jâai ajouter la configuration dans mon configuration.yaml
zha:
database_path: zigbee.db
custom_quirks_path: /config/custom_zha_quirks/
Puis jâai importer le fichier light.py dans mon folder custom_zha_quirks
Mais lorsque je test la configuration avant de relancer HA jâai cette erreur :
Invalid config for [zha]: not a directory for dictionary value @ data['zha']['custom_quirks_path']. Got '/config/custom_zha_quirks/'. (See /config/configuration.yaml, line 35).
Une idée ?
Moi jâai ceci
configuration.yaml
zha:
custom_quirks_path: /config/zhaquirks/
et jây ai copiĂ© les fichiers thermostat.py, light.py, sensor.py et switch.py de mon sinope-zha
Peut-ĂȘtre que le nom du rĂ©pertoire est spĂ©cifique. Par contre pour tes DM2500ZB ils sont dĂ©jĂ supportĂ©s dans ZHA. Tu vas avoir besoin du zhaquirks seulement pour ton Calypso
Jâai essayĂ© la mĂȘme configuration que toi mais jâai toujours la mĂȘme erreur. Mais comme tu dis jâai pu confirmer que ZHA possĂ©de dĂ©jĂ les rĂ©fĂ©rences pour SinopĂ©
Jâai correctement dĂ©couvert lâinterrupteur mais jâai les problĂšmes suivants :
Pour mon sinope-zha jây met les dĂ©veloppements pour pouvoir tester et quand ca fonctionne je lance un PR dans zha. Ca Ă©vite dâattendre aprĂšs les update de zha et de HA
Pour changer les valeurs tu dois utiliser le service zha.set_zigbee_cluster_attribute
Dans la doc de mon sinope-zha il y a tous les cluster et attributs que jâai trouvĂ© pour les appareils sinopĂ©
Effectivement jâavais vue ca, mais quel serait la dĂ©marche pour populer les controles directements dans HA ? Bizarement il nây a que le On_Level
Semblerait que lâon doit dĂ©finir : device_automation_triggers
Câest bien ca me fait pousser mes connaissance zigbee/HA cette histoire
Iâve Resent my post since my name was at the bottom of the picutre.,
@claudegel Even if it is written TH1124ZB-G2 on the TH1123ZB-G2 package, it seems like there is no g2 version for the TH1124ZB (according to the person who replied to me via sinope sales
Hi @MattL0 Maybe it is not out yet but it is listed in Neviweb technical doc. So Iâve added it.
Weâll be ready when they launch it.
It was the same for the calypso tank controller. Iâve added it to neviweb130 before it came on sale.
For those who are using the Calypso water tank controller in ZHA. I just finished to add specific attributes for manufacturer cluster. I also put some documentation for those clusters and attributes in README.md
Please test and download the file switch.py to replace the one you already use in the zhaquirks.
Thank you very much for all the work youâve done ! I just connected mine today and will work on the configuration asap. will provide you some feedback
Bonjour, je suis nouveau avec Home Assistant et SinopĂ©. Je possĂšde 11 thermostats SinopĂ© Zigbee ainsi que la passerelle GT130. Jâutilise Neviweb.com sur mon portable Windows 10 pour la configuration de ceux-ci, par contre, je trouve le tout incomplet et un peu basique. Jâaimerais savoir quel est le matĂ©riel que vous utilisez pour placer le code github.com/claudegel/sinope-130
Si je comprends bien, toutes les données sont enregistrées dans la passerelle GT130 alors comment relier Home Assistant avec mon matériel, que me manque t-il selon vous ⊠merci pour votre aide
Bonjour @rayd57. Il y a deux façon de relier vos appareils zigbee à Home Assistant. Soit via une passerelle zigbee comme le Conbee II usb ou en utilisant le custom_component sinope Neviweb130.
Puisque tu as dĂ©jĂ un GT130 alors il faut installer mon custom_component sinope Neviweb130. le plus simple est dâinstaller en premier HACS https://hacs.xyz/. Ensuite tu redĂ©marre HA et aprĂšs quelques minutes HACS va populer sa liste de components et tu pourras installer Sinope Neviweb130.
Dans configuration.yaml tu dois ajouter les lignes suivantes:
neviweb130:
username: !secret climate_username # courriel utilisé pour connecter à Neviweb
password: !secret climate_password # mot de passe Neviweb
network: !secret climate_gateway130 # nom de l'emplacement inscrit au haut de la page dans Neviweb
scan_interval: 360 # la fréquence pour récupérer les données des appareils dans Neviweb
Ajoute aussi du débug:
logger:
default: warning
logs:
homeassistant.custom_components: debug
custom_components.neviweb130: debug
Ensuite redémarre HA et tu verras apparaitre tes appareils dans HA
I have a weird issue with my kitchen thermostat. The display was totally black and it was not heating. I looked at the breaker, it wasnât jumped, turned it off and on anyway, didnât change anything.
I was still seing it in my home-assistant, ZHA. Could raise and lower setpoint but would not heat.
I looked at the entity and the vacation was showing âheatingâ, meaning value = 1 (away). So I sent a cluster attribute change in ZHA to 0 and it turned to idle. Then it stated heating.
Itâs the only thermostat that does this, itâs also the only thermostat that is with a âfanâ as itâs a undercabinet electrical fan unit.
I have no automation other than the outdoor temp value and the display automatic for the bedroom when I go to bed and turn on in the morning.
No away or home mode etc⊠So I donât understand it. I use the ZHA instead of neviweb now so I have a faster control.
Not itâs still in âheatingâ mode but the display is still there. I wonder whatâs the issue.
