I still get an error that it failed to perform an action. Again, two logs are generated:
Logger: homeassistant.helpers.script.websocket_api_script
Source: helpers/script.py:525
First occurred: 6:44:04 PM (4 occurrences)
Last logged: 6:51:30 PM
websocket_api script: Error executing script. Unexpected error for call_service at pos 1: 'NoneType' object has no attribute 'bus'
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 525, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 763, in _async_call_service_step
response_data = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 726, in _async_run_long_action
return await long_task
File "/usr/src/homeassistant/homeassistant/core.py", line 2761, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2804, in _execute_service
return await target(service_call)
File "/config/custom_components/zha_toolkit/__init__.py", line 813, in toolkit_service
u.get_hass(zha_gw).bus.fire(params[p.EVT_FAIL], event_data)
AttributeError: 'NoneType' object has no attribute 'bus'
Logger: homeassistant.components.websocket_api.http.connection
Source: custom_components/zha_toolkit/__init__.py:813
integration: Home Assistant WebSocket API (documentation, issues)
[140125197409952] Error handling message: Unknown error (unknown_error) Pip from 192.168.20.201 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/128.0.0.0 Safari/537.36)
[140125197411824] Error handling message: Unknown error (unknown_error) Pip from 192.168.20.201 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/128.0.0.0 Safari/537.36)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 28, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 816, in handle_execute_script
script_result = await script_obj.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1795, in async_run
return await asyncio.shield(create_eager_task(run.async_run()))
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 463, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 527, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 557, in _handle_exception
raise exception
I"ve tried calling it as both an action and a service and get the same error.
