Continuing the discussion from SIP Client:
thx for the quick answer didn’t expect that ![]()
forgot to mention that. I meant, if the LAN2WAN bridge could now be done using HA’s android app, is that possible?
thought the same although I could LAN SIP-Provider in parallel, couldn’t I? Call local first and couple of seconds later I call the SIP-Cloud-Number, to minimize bandwidth issues.
I spoke with their tec-line a couple of days ago, it is not unlikely that their system will be installed (it is still cheaper as the Swiss standard system
Moreover, there might be an integration what uses their LAN-2-LAN API
