SIP client card, as intercom
Yeah, still need to optimize it of course but it could still end up around 10%. Asterisk does use a bit.
But I didn’t do anything that would increase the CPU usage in the test. Please let me know if it changes.
But I think I will start on the integration, so it is actually usable with the new card and automations.
ah ok , so the add-on on hold?
I will still try some things to get the add-on working.
first of all, thank you for your work and this great addon,
once it is done, it will be the greatest integration for HA
but for now, I’m also experiencing about 50% increase in CPU load since I updated the addon (12 hours ago)
thanks again for your effort!
Thanks! :slight_smile:
And thank you for letting me know about the CPU load. I will look into it.
I’m really interested in this addon. I think this may add the final missing piece to making truly local video doorbells as we don’t have a good 2 way audio implementation. Now can anyone suggest a video doorbell to me that’ll work with a SIP server?
Also can the home-assistant dashboard receive a call and transmit your voice via the web browser currently displaying the dashboard widget?
I don’t know any good SIP video doorbells, but do not use Ring!
The card can auto pickup, but cannot see which browsers are displaying the card since the cards are still loaded when you go to another screen. You could call all persons to call with the first one to pickup. But this is all in the future. Maybe there will be another way to do this.
Stay away from Hikvision, their SIP is quite limited…i have hikvision, it should work, i have tested before
for good SIP, try to search for Doorbird maybe
I’m using Dahua, it’s a good alternative
I’m running the vto 2202 dahua, from reviews the sip is supposed to work quite well but I am still setting up asterisk to test it out.
Hello All,
I try to make a call . I setup a FreePBX Server apart from Home assistant. The websocket is passed thriugh nginx proxy and reachable. Once I try to make a call I get this error from the calling card:
logger-factory.ts:109 Mon Nov 22 2021 21:29:42 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] Beginning Session...
logger-factory.ts:109 Mon Nov 22 2021 21:29:42 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Inviter | Inviter.invite
logger-factory.ts:109 Mon Nov 22 2021 21:29:42 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Inviter | Session bpfgs087us59qm5j6p52hi1s0lkqrs transitioned to state Establishing
logger-factory.ts:109 Mon Nov 22 2021 21:29:42 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] session state changed to Establishing
logger-factory.ts:109 Mon Nov 22 2021 21:29:42 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | Sending WebSocket message:
INVITE sip:[email protected] SIP/2.0
Via: SIP/2.0/WSS rorb8vkmqm6q.invalid;branch=z9hG4bK3132013
To: <sip:[email protected]>
CSeq: 1 INVITE
Call-ID: bpfgs087us59qm5j6p52
Max-Forwards: 70
Contact: <sip:[email protected];transport=ws;ob>
Allow: ACK,CANCEL,INVITE,MESSAGE,BYE,OPTIONS,INFO,NOTIFY,REFER
Supported: outbound
User-Agent: SIP.js/0.20.0
Content-Type: application/sdp
Content-Length: 2110
v=0
o=- 8971555575853491424 2 IN IP4 127.0.0.1
s=-
t=0 0
a=group:BUNDLE 0
a=extmap-allow-mixed
a=msid-semantic: WMS 6397b014-7d1c-4dee-b153-a42d9a642cb3
m=audio 49770 UDP/TLS/RTP/SAVPF 111 63 103 104 9 0 8 106 105 13 110 112 113 126
c=IN IP4 92.170.194.152
a=rtcp:9 IN IP4 0.0.0.0
a=candidate:3960087712 1 udp 2122260223 30.30.30.36 49770 typ host generation 0 network-id 1 network-cost 10
a=candidate:1163242357 1 udp 1686052607 92.170.194.152 49770 typ srflx raddr 30.30.30.36 rport 49770 generation 0 network-id 1 network-cost 10
a=candidate:2726942800 1 tcp 1518280447 30.30.30.36 9 typ host tcptype active generation 0 network-id 1 network-cost 10
a=ice-ufrag:yYpa
a=ice-pwd:tzhJ7zxtTJPOoFRgDMcP4md8
a=ice-options:trickle
a=fingerprint:sha-256 7C:BA:C5:E8:23:89:49:FB:B4:A2:EB:75:56:99:E7:34:C0:18:64:3E:49:6A:D7:0A:5F:B7:FA:B7:58:C3:AF:F8
a=setup:actpass
a=mid:0
a=extmap:1 urn:ietf:params:rtp-hdrext:ssrc-audio-level
a=extmap:2 http://www.webrtc.org/experiments/rtp-hdrext/abs-send-time
a=extmap:3 http://www.ietf.org/id/draft-holmer-rmcat-transport-wide-cc-extensions-01
a=extmap:4 urn:ietf:params:rtp-hdrext:sdes:mid
a=extmap:5 urn:ietf:params:rtp-hdrext:sdes:rtp-stream-id
a=extmap:6 urn:ietf:params:rtp-hdrext:sdes:repaired-rtp-stream-id
a=sendrecv
a=msid:6397b014-7d1c-4dee-b153-a42d9a642cb3 57a4d7ce-7db2-41cc-bc0a-cf82590469eb
a=rtcp-mux
a=rtpmap:111 opus/48000/2
a=rtcp-fb:111 transport-cc
a=fmtp:111 minptime=10;useinbandfec=1
a=rtpmap:63 red/48000/2
a=fmtp:63 111/111
a=rtpmap:103 ISAC/16000
a=rtpmap:104 ISAC/32000
a=rtpmap:9 G722/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:106 CN/32000
a=rtpmap:105 CN/16000
a=rtpmap:13 CN/8000
a=rtpmap:110 telephone-event/48000
a=rtpmap:112 telephone-event/32000
a=rtpmap:113 telephone-event/16000
a=rtpmap:126 telephone-event/8000
a=ssrc:3250730075 cname:iHVf//ykQSZQamSm
a=ssrc:3250730075 msid:6397b014-7d1c-4dee-b153-a42d9a642cb3 57a4d7ce-7db2-41cc-bc0a-cf82590469eb
a=ssrc:3250730075 mslabel:6397b014-7d1c-4dee-b153-a42d9a642cb3
a=ssrc:3250730075 label:57a4d7ce-7db2-41cc-bc0a-cf82590469eb
logger-factory.ts:109 Mon Nov 22 2021 21:29:42 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] sent INVITE
logger-factory.ts:109 Mon Nov 22 2021 21:29:42 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | Received WebSocket text message:
SIP/2.0 488 Not acceptable here
Via: SIP/2.0/WSS rorb8vkmqm6q.invalid;branch=z9hG4bK3132013;received=172.19.0.1;rport=60826
To: <sip:[email protected]>;tag=as646ec8eb
CSeq: 1 INVITE
Server: FPBX-15.0.17.62(17.9.3)
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Supported: replaces, timer
Content-Length: 0
ACK sip:[email protected] SIP/2.0
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
logger-factory.ts:109 Mon Nov 22 2021 21:29:42 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Inviter | Inviter.onReject
logger-factory.ts:109 Mon Nov 22 2021 21:29:42 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Inviter | Session bpfgs087us59qm5j6p52hi1s0lkqrs transitioned to state Terminated
logger-factory.ts:109 Mon Nov 22 2021 21:29:42 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] session state changed to Terminated
logger-factory.ts:109 Mon Nov 22 2021 21:29:42 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Inviter | Session bpfgs087us59qm5j6p52hi1s0lkqrs in state Terminated is being disposed
logger-factory.ts:105 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | WebSocket closed unexpectedly
print @ logger-factory.ts:105
genericLog @ logger-factory.ts:79
genericLog @ logger.ts:33
warn @ logger.ts:23
onWebSocketClose @ transport.ts:409
(anonymous) @ transport.ts:256
logger-factory.ts:109 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | WebSocket closed wss://home-access.ddns.me/ws (code: 1006)
logger-factory.ts:109 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | Transitioned from Connected to Disconnected
logger-factory.ts:109 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] Disconnected
logger-factory.ts:109 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] Unregistering...
logger-factory.ts:105 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Registerer | Not currently registered, but sending an unregister anyway.
warn @ logger.ts:23
unregister @ registerer.ts:562
onDisconnect @ simple-user.ts:131
onTransportDisconnect @ user-agent.ts:867
transport.onDisconnect @ user-agent.ts:849
transitionState @ transport.ts:624
onWebSocketClose @ transport.ts:417
logger-factory.ts:109 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Registerer | Waiting toggled to true
logger-factory.ts:109 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | Sending WebSocket message:
REGISTER sip:anonymous.invalid SIP/2.0
Via: SIP/2.0/WSS p09o3cge2b0q.invalid;branch=z9hG4bK4596648
CSeq: 26 REGISTER
Call-ID: qdgk013brkoq2t7s9da1
Max-Forwards: 70
Authorization: Digest algorithm=MD5, username="anonymous.j2c5e1", realm="asterisk", nonce="49cd2e69", uri="sip:anonymous.invalid", response="4f74964edfd21e0c8714abc529d7d52f"
Contact: <sip:[email protected];transport=ws>;expires=0
Supported: outbound, path, gruu
Content-Length: 0
logger-factory.ts:109 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] Reconnection attempt 1 of 3 - trying
logger-factory.ts:101 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.user-agent-client | Not connected.
print @ logger-factory.ts:101
error @ logger.ts:20
onTransportError @ user-agent-client.ts:296
onTransportError @ user-agent-client.ts:368
onTransportError @ non-invite-client-transaction.ts:158
(anonymous) @ transaction.ts:130
Promise.catch (async)
send @ transaction.ts:116
NonInviteClientTransaction @ non-invite-client-transaction.ts:42
init @ user-agent-client.ts:372
UserAgentClient @ user-agent-client.ts:58
RegisterUserAgentClient @ register-user-agent-client.ts:12
register @ user-agent-core.ts:161
unregister @ registerer.ts:608
logger-factory.ts:101 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.user-agent-client | User agent client request transport error. Generating internal 503 Service Unavailable.
onTransportError @ user-agent-client.ts:297
logger-factory.ts:101 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Registerer | Unregister rejected with status code 503
onReject @ registerer.ts:631
receiveResponse @ user-agent-client.ts:341
onTransportError @ user-agent-client.ts:301
logger-factory.ts:109 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Registerer | Waiting toggled to false
logger-factory.ts:101 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.transaction.nict | Not connected.
logTransportError @ transaction.ts:104
(anonymous) @ non-invite-client-transaction.ts:43
logger-factory.ts:101 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.transaction.nict | Transport error occurred in non-INVITE client transaction with id z9hG4bK4596648.
logTransportError @ transaction.ts:105
logger-factory.ts:101 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.transaction.nict | Failed to send initial outgoing request.
logTransportError @ transaction.ts:106
logger-factory.ts:109 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | Connecting wss://home-access.ddns.me/ws
logger-factory.ts:109 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | Transitioned from Disconnected to Connecting
logger-factory.ts:109 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | WebSocket opened wss://home-access.ddns.me/ws
logger-factory.ts:109 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | Transitioned from Connecting to Connected
logger-factory.ts:109 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] Connected
logger-factory.ts:109 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] Registering...
Via: SIP/2.0/WSS p09o3cge2b0q.invalid;branch=z9hG4bK6349061
CSeq: 27 REGISTER
Max-Forwards: 70
Contact: <sip:[email protected];transport=ws>;expires=600
Content-Length: 0
logger-factory.ts:109 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] Reconnection attempt 1 of 3 - succeeded
logger-factory.ts:109 Mon Nov 22 2021 21:29:46 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | Received WebSocket text message:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/WSS p09o3cge2b0q.invalid;branch=z9hG4bK6349061;received=172.19.0.1;rport=34256
To: <sip:[email protected]>;tag=as209819a4
CSeq: 27 REGISTER
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="416bc28e"
Content-Length: 0
logger-factory.ts:109 Mon Nov 22 2021 21:29:57 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] Reconnection attempt 1 of 3 - succeeded
logger-factory.ts:109 Mon Nov 22 2021 21:29:57 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | Received WebSocket text message:
Via: SIP/2.0/WSS r6343hniv459.invalid;branch=z9hG4bK8435235;received=172.19.0.1;rport=34374
To: <sip:[email protected]>;tag=as658bdddb
Call-ID: vp9ter9g2tpkg3q4958m
CSeq: 33 REGISTER
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="166bbabc"
Content-Length: 0
logger-factory.ts:109 Mon Nov 22 2021 21:29:57 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | Sending WebSocket message:
Via: SIP/2.0/WSS r6343hniv459.invalid;branch=z9hG4bK8472035
CSeq: 34 REGISTER
Max-Forwards: 70
Authorization: Digest algorithm=MD5, username="anonymous.5m8bk7", realm="asterisk", nonce="166bbabc", uri="sip:anonymous.invalid", response="95ebbb56990dc2ab479b9e97a7930add"
Content-Length: 0
SIP/2.0 403 Forbidden
Via: SIP/2.0/WSS r6343hniv459.invalid;branch=z9hG4bK8472035;received=172.19.0.1;rport=34374
CSeq: 34 REGISTER
Content-Length: 0
logger-factory.ts:105 Mon Nov 22 2021 21:29:57 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Registerer | Failed to register, status code 403
warn @ logger.ts:23
onReject @ registerer.ts:500
receiveResponse @ user-agent-client.ts:369
receiveResponse @ non-invite-client-transaction.ts:101
receiveResponseFromTransport @ user-agent-core.ts:898
receiveIncomingResponseFromTransport @ user-agent-core.ts:253
onTransportMessage @ user-agent.ts:972
transport.onMessage @ user-agent.ts:850
onWebSocketMessage @ transport.ts:488
(anonymous) @ transport.ts:259
logger-factory.ts:109 Mon Nov 22 2021 21:29:57 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Registerer | Waiting toggled to false
logger-factory.ts:105 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | WebSocket closed unexpectedly
warn @ logger.ts:23
logger-factory.ts:109 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | WebSocket closed wss://home-access.ddns.me/ws (code: 1006)
logger-factory.ts:109 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | Transitioned from Connected to Disconnected
logger-factory.ts:109 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] Disconnected
logger-factory.ts:109 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] Unregistering...
logger-factory.ts:105 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Registerer | Not currently registered, but sending an unregister anyway.
warn @ logger.ts:23
logger-factory.ts:109 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Registerer | Waiting toggled to true
logger-factory.ts:109 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | Sending WebSocket message:
Via: SIP/2.0/WSS 9olc622l5kas.invalid;branch=z9hG4bK6557992
CSeq: 29 REGISTER
Call-ID: fvf4ncu5r6olbtaek3lb
Max-Forwards: 70
Authorization: Digest algorithm=MD5, username="anonymous.d3m2pl", realm="asterisk", nonce="429bc333", uri="sip:anonymous.invalid", response="7873073bd96d7978d7bc92ccdcee5a0c"
Content-Length: 0
logger-factory.ts:109 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] Reconnection attempt 1 of 3 - trying
logger-factory.ts:101 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.user-agent-client | Not connected.
logger-factory.ts:101 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.user-agent-client | User agent client request transport error. Generating internal 503 Service Unavailable.
logger-factory.ts:101 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Registerer | Unregister rejected with status code 503
logger-factory.ts:109 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Registerer | Waiting toggled to false
logger-factory.ts:101 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.transaction.nict | Not connected.
logger-factory.ts:101 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.transaction.nict | Transport error occurred in non-INVITE client transaction with id z9hG4bK6557992.
logger-factory.ts:101 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.transaction.nict | Failed to send initial outgoing request.
logger-factory.ts:109 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | Connecting wss://home-access.ddns.me/ws
logger-factory.ts:109 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | Transitioned from Disconnected to Connecting
logger-factory.ts:109 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | WebSocket opened wss://home-access.ddns.me/ws
logger-factory.ts:109 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | Transitioned from Connecting to Connected
logger-factory.ts:109 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] Connected
logger-factory.ts:109 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] Registering...
Via: SIP/2.0/WSS 9olc622l5kas.invalid;branch=z9hG4bK261264
CSeq: 30 REGISTER
Max-Forwards: 70
Content-Length: 0
logger-factory.ts:109 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.SimpleUser | [Anonymous] Reconnection attempt 1 of 3 - succeeded
logger-factory.ts:109 Mon Nov 22 2021 21:30:03 GMT+0100 (Mitteleuropäische Normalzeit) | sip.Transport | Received WebSocket text message:
Via: SIP/2.0/WSS 9olc622l5kas.invalid;branch=z9hG4bK261264;received=172.19.0.1;rport=34428
To: <sip:[email protected]>;tag=as3e27e415
CSeq: 30 REGISTER
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="76b6fc7e"
Content-Length: 0
My config looks like:
Card
type: custom:sipjs-client-card
server: wss://home-access.ddns.me/ws
ringtone: /local/ringtone.mp3
clients:
  test1:
    aor: sip:[email protected]
    username: 101
    password: network
  7de68fce-5e7bf92d:
    username: 102
    password: dashbaord
If I well understand the Card is communicating with the FreePBX server right? Seems just like registering fails… I get this Unathorized error.
Help would be highly appreciated. I would for thanks write a detailed instruction how to setup this card with server if I get it running guys :slight_smile:
It try’s to register as anonymous which Asterisk doesn’t allow. So it seems like the card can’t choose a extension. Is your deviceID correct?
I bought a Dahua VTO 2211G-WP for this specific reason. Still mucking through setting it up with FreePBX while it is sitting on my file cabinet before I install it, but this new card is making me hopeful for an intercom system within HA.
Can I ask here are people mostly using asterisk or some other PBX? And can they recommend any guides to setting one up that will be compatible with this card?
This card will use asterisk/FreePBX… It uses websocket for it, don’t think it’s possible to use another PBX…
If you want to test other systems , without this card, i like free switch/fusionpbx
yes the device ID is correct.
I tried yesterday with my phone and it rang… so it is basically working but the card “not”
maybe we can add a discord channel for this card `?
Discord channel is a good idea!
From the log it looks like you are trying to call 102 from 101. I think your deviceID from 101 is wrong so it doesn’t choose any extension. Replace test1 with the deviceID you want to call 102 with.
all right… Like i said i am nit using your addon only the card. do you want me to setup a discord channel? I will write a complete setup guide if we get it running together :slight_smile: I guess u r German right? maybe we can also discuss via voice to get ahead better? I also speak french if u want :stuck_out_tongue:
I am talking about the card.
Already made a quick discord server. HA-SIP I am actually Dutch. :slight_smile:
Can’t speak until 15:00.
dutch , me too, where are you from? be or nl?
