SiriusXM Integration into HA
I’m looking for a way to integrate the SiriusXM radio stations into HA.
I couldn’t find much other than it showing up with in the Echo Device Media player post but all I really need is if anyone has any ideas on how to login with a valid subscription to Sirius XM streaming through HA and have the radio channels exposed to HA.
https://community.home-assistant.io/t/echo-devices-alexa-as-media-player-testers-needed/
Thanks!
C
I would like to see this also…
Me as well!
The Gracedigital Radios communicate with their phone apps using JSON - I’ve gotten part of the command set deciphered. I’ve decoded, on/off, volume, mute, source change (SIRIUS,DLNA,USB,FM Station), media enumeration. Should I create a github project and release what I have so that others smarter than I can finish it up? I just don’t have the time. It looks like that gracedigital has run just about everyone else out of the market. The Yamaha receivers on the integration list are all discontinued.
It appears that Music Assistant can use SiriusXM as a music provider. That might be worth investigating.
