Hi, I’m completely new to Linux. I cannot connect via IP to Home Assistant, it says “This site can’t be reached”.
- I installed the Raspberry Pi OS from scratch
- Followed the official Docker Debian [Install using the apt repository] instruction since I’m using the 64-bit version
- Then followed the official [Manage Docker as a non-root user] instructions
- Afterwards installed the Compose Plugin [Install using the repository]
- Installed Portainer using this the YAML file and this instruction
version: '3.0'
services:
portainer:
container_name: portainer
image: portainer/portainer-ce
restart: always
ports:
- "9000:9000/tcp"
environment:
- TZ=Europe/London
volumes:
- /var/run/docker.sock:/var/run/docker.sock
- /opt/portainer:/data
- Then I installed Docker Compose following these instructions
Everything seems to be working fine. I can open Portainer in my browser and the HA container is also showing up and is running. However I’m not able to connect to HA via the IP:8123
Is there anything I did wrong in the setup process that might be causing this issue? Any help would be much apprechiated!
