Is it possible to create individual widgets with different widget_dimension than default?
please dont ask the same questions on different places.
i will see the question when you put it here or on discord or in another topic, but 1 time is enough
for others that read this:
no you cant set dimensions for an individual widget, that would break the grid, thats why that option isnt there.
however you can set the dimensions smaller (for example 30x30)
if you combine that with the default widget_size from (4x4) all widgets will still be 120x120
however if you then in the layout use spacer(1x1) you only would see a space from 30x30
