Sizing cards
Is there any way to size/allign cards? specialy in height:
I am currently using horizontal-stacks (in panel mode) and then add the cards to the horizontal stack. For a new line, use a new horizontal-stack
Yes I am using that to, but they do not allign,
I would like to give the cards a standard height
Sorry, I meant a vertical-stack, and then horizontal-stacks. Like this
  - title: Test
    path: test
    visible:
      - user: d9b7259c90364490937b8347d572cae8
      - user: 973007d609a743b1a3f8014241746382
    type: panel
    badges: []
    cards:
      - type: vertical-stack
        cards:
          - type: glance
            entities:
              - sensor.studeerkamer_mexicaanse_bergpalm_temperature
              - sensor.studeerkamer_mexicaanse_bergpalm_light_intensity
              - sensor.studeerkamer_mexicaanse_bergpalm_moisture
          - type: horizontal-stack
            cards:
              - type: entity
                entity: sensor.studeerkamer_mexicaanse_bergpalm_temperature
              - type: picture
                image: https://demo.home-assistant.io/stub_config/t-shirt-promo.png
                tap_action:
                  action: none
                hold_action:
                  action: none
            cards:
              - type: entity
              - type: entities
                entities:
                  - entity: sensor.studeerkamer_mexicaanse_bergpalm_temperature
                  - entity: sensor.studeerkamer_mexicaanse_bergpalm_light_intensity
This is what it looks like:
Notice the same entity card on row 2 and 3 are different sizes based on the card next to it
Maybe try this
Yes this is what i mean, so they get the same because of the horizontal stack in it?
Will try it soon. Thanks
Will try this one tho! thanks
cards:
    cards:
      - type: entities
        entities:
          - entity: binary_sensor.rpi_power_status
          - entity: binary_sensor.updater
          - entity: sensor.installed_version
            name: HA Installed Version
            icon: mdi:home-assistant
          - entity: sensor.latest_available_version
            name: HA Latest Available Version
          - entity: sensor.hacs
          - entity: sensor.last_boot
          - entity: sensor.home_assistant_v2_db
        state_color: true
        title: Systeem
        show_header_toggle: true
      - type: custom:bar-card
        entities:
          - entity: sensor.processor_use
        title: Prestaties
        columns: '1'
        direction: right
        height: 40px
        decimal: '1'
        min: '0'
        max: '100'
        unit_of_measurement: '%'
        positions:
          icon: outside
          indicator: inside
          minmax: 'off'
          value: inside
        severity:
            to: '10'
            to: '50'
            color: orange
            to: '100'
            color: red
        entity_row: true
        entities:
          - entity: sensor.memory_use_percent
        columns: '1'
        direction: right
        height: 40px
        decimal: '1'
        min: '0'
        max: '100'
        positions:
          icon: outside
          indicator: inside
          minmax: 'off'
          value: inside
        severity:
            to: '35'
            to: '75'
            color: orange
            to: '100'
            color: red
        entity_row: true
        entities:
          - entity: sensor.disk_use_percent
        entity_row: true
        columns: '1'
        direction: right
        height: 40px
        decimal: '1'
        min: '0'
        max: '100'
        positions:
          icon: outside
          indicator: inside
          minmax: 'off'
          value: inside
        severity:
            to: '35'
            to: '70'
            color: orange
            to: '100'
            color: red
        entities:
          - entity: sensor.cpu_temp
        entity_row: true
        columns: '1'
        direction: right
        height: 40px
        decimal: '1'
        min: '45'
        max: '85'
        positions:
          icon: outside
          indicator: inside
          minmax: 'off'
          value: inside
        severity:
            to: '63'
            color: green
            to: '72'
            color: orange
            to: '85'
            color: red
          - type: divider
    cards:
      - type: glance
        title: Component Count
        columns: 4
        entities:
          - entity: sensor.count_automations
            icon: mdi:autorenew
          - entity: sensor.count_scripts
            icon: mdi:script-text-outline
          - entity: sensor.count_zones
            icon: mdi:map-marker-radius
          - entity: sensor.count_device_trackers
          - entity: sensor.count_switches
            icon: mdi:light-switch
          - entity: sensor.count_sensors
            icon: mdi:resistor
          - entity: sensor.count_binary_sensors
            icon: mdi:unfold-more-horizontal
          - entity: sensor.count_input_booleans
            icon: mdi:toggle-switch
          - entity: sensor.count_input_numbers
            icon: mdi:numeric
          - entity: sensor.count_input_texts
            icon: mdi:alphabetical
          - entity: sensor.count_input_selects
            icon: mdi:view-list
          - entity: sensor.count_input_datetimes
            name: Input Date Times
            icon: mdi:calendar-clock
        state_color: true
      - type: entities
        entities:
          - entity: binary_sensor.check_home_assistant_configuration_update_available
          - entity: binary_sensor.home_assistant_operating_system_update_available
          - entity: binary_sensor.samba_share_update_available
          - entity: binary_sensor.terminal_ssh_update_available
          - entity: binary_sensor.visual_studio_code_update_available
        state_color: true
        title: Updates
Seems i have horizantal first and than vertical, can that be the problem, or anything els wrong in here?
As far as I can see that is the problem. Set the first card to vertical, and change de subcards from vertical to horizontal.
Much better :slight_smile:
Hello I am pretty new with HA and coding in general, i am resuming this old post because it is what i am looking for as eas way to reallign the card in my dash board.
i guess i learnt enough about the yaml configuration, but trying to add the comment below:
cards:
to RAW dsashboard config, cards are still wrongly alligned horizzontally and vertically, this is the beginning of the RAW file (just the beginning):
background: var(--background-image)
title: Casa
     - theme: transparentblue
    path: default_view
    title: Home
    subview: false
    icon: mdi:home
    badges: []
    cards:
      - type: entities
        entities:
          - entity: switch.shelly_shellyplus1_a8032abd70e4
          - entity: sensor.shelly_shellyplus1_a8032abd70e4_device_temp
        title: Camera da letto
        state_color: true
      - type: entities
where, in my RAW file, i have to put those comments to make it working?
i did many attempt but without success.
then, where i can find out some basic tutorial to better understand the yaml scripting and the basic function, for a better understanding about the synthax?
thanks
I have no idea how to do that , in this screen , can do most back end stuff but this front end eludes me
I think you have to install HACS and use the custom grid card and layout card
