Perhaps something like this?
I don’t know what that inject was and how it works not when I exported it since I don’t have that node.
But you need to change the YourBoolean with the boolean you have on your lovelace.
[{"id":"5b88d430.15a1dc","type":"api-current-state","z":"53216960.0cb138","name":"Türsensor Balkon","server":"818794df.29c548","version":2,"outputs":2,"halt_if":"true","halt_if_type":"bool","halt_if_compare":"is","override_topic":false,"entity_id":"binary_sensor.lumi_tuersensor_balkon","state_type":"habool","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":470,"y":80,"wires":[[],["e6646389.5946e"]]},{"id":"1f110e35.6bf072","type":"time-inject","z":"53216960.0cb138","name":"","nameInt":"⏲ Sonnenuntergang Ende↷ = 0.3","positionConfig":"11453379.f62a8d","props":[{"p":"","pt":"msgPayload","v":"0.3","vt":"num","o":"1","oT":"none","oM":"60000","f":0,"fS":0,"fT":"Millisekunden UNIX-Zeit","fI":"0","next":true,"days":""},{"p":"","pt":"msgTopic","v":"","vt":"str","o":"1","oT":"none","oM":"60000","f":0,"fS":0,"fT":"Millisekunden UNIX-Zeit","fI":"0","next":false,"days":""}],"injectTypeSelect":"time","intervalCount":1,"intervalCountType":"num","intervalCountMultiplier":60000,"time":"sunset","timeType":"pdsTime","offset":"1815","offsetType":"num","offsetMultiplier":1000,"timeEnd":"","timeEndType":"entered","timeEndOffset":0,"timeEndOffsetType":"num","timeEndOffsetMultiplier":60000,"timeDays":"*","timeOnlyOddDays":true,"timeOnlyEvenDays":true,"timeMonths":"*","timedatestart":"","timedateend":"","property":"","propertyType":"none","propertyCompare":"true","propertyThreshold":"","propertyThresholdType":"num","timeAlt":"","timeAltType":"entered","timeAltDays":"*","timeAltOnlyOddDays":true,"timeAltOnlyEvenDays":true,"timeAltMonths":"*","timeAltOffset":0,"timeAltOffsetType":"none","timeAltOffsetMultiplier":60000,"once":false,"onceDelay":0.1,"recalcTime":2,"x":200,"y":80,"wires":[["5b88d430.15a1dc"]]},{"id":"e6646389.5946e","type":"api-current-state","z":"53216960.0cb138","name":"","server":"4bbca37b.1700ec","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_boolean.YourBoolean","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":760,"y":80,"wires":[["6a6af191.3c29d"],["d412a721.42ac18"]]},{"id":"d412a721.42ac18","type":"api-call-service","z":"53216960.0cb138","name":"Rollladen WoZi Balkon ab","server":"818794df.29c548","version":3,"debugenabled":false,"service_domain":"cover","service":"close_cover","entityId":"cover.wozi_rollladen_balkon","data":"","dataType":"jsonata","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1090,"y":120,"wires":[[]]},{"id":"6a6af191.3c29d","type":"api-call-service","z":"53216960.0cb138","name":"","server":"4bbca37b.1700ec","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.YourBoolean","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1100,"y":40,"wires":[[]]},{"id":"818794df.29c548","type":"server","name":"Home Assistant","addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true},{"id":"4bbca37b.1700ec","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
