Hi, I want to set a automation which reminds me 14 days in a row and skips the next 7 days. My first try used now().isocalendar() with a startweek and modulo. But it will break every year as the week number resets.
Save the time in an input datetime helper every time it runs and use that in a template trigger with a delta of 14 days. You will need to give the input datetime an initial value.
How about a counter set at 14, each reminder makes the counter count down.
When the counter is 0 then set a new date when it should start counting as a helper.
Something like this:
description: ""
mode: single
- platform: time
at: "09:00:00"
condition:
- condition: numeric_state
entity_id: counter.counter
above: 0
- condition: time
after: input_datetime.alarm_time
- service: tts.cloud_say
entity_id: media_player.player
message: Reminder
- service: counter.decrement
data: {}
- choose:
- conditions:
- condition: state
state: "0"
sequence:
- service: counter.configure
value: 14
- service: input_datetime.set_datetime
timestamp: "{{ as_timestamp(now() + timedelta(days = 7)) - 3600 }}"
entity_id: input_datetime.alarm_time
You could still use modulo, but just convert the timestamp to weeks, so it ignores new years.
{{ (now() | as_timestamp / 60 / 60 / 24 / 7) | int % 3 }}
Another variation based on this: Again use a counter, but just keep incrementing it day by day and do a modulo 14. Even with an int you’re not going to run out in a lifetime. Option A by Hellis is perhaps better if you want to see “days until” on a dashboard.
