Previously working skybell component stopped working after a reboot.
Before that specific reboot it worked fine.
Restarting hass had no effect and the error remains
the following shows up in the log file:
2017-12-01 19:58:44 ERROR (MainThread) [homeassistant.setup] Error during setup of component skybell
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py”, line 193, in _async_setup_component
component.setup, hass, processed_config)
File “/usr/lib/python3.5/asyncio/futures.py”, line 380, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.5/asyncio/tasks.py”, line 304, in _wakeup
future.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
raise self._exception
File “/usr/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/skybell.py”, line 49, in setup
get_devices=True, cache_path=cache)
File “/srv/homeassistant/lib/python3.5/site-packages/skybellpy/init.py”, line 58, in init
self._load_cache()
File “/srv/homeassistant/lib/python3.5/site-packages/skybellpy/init.py”, line 229, in _load_cache
loaded_cache = UTILS.load_cache(self._cache_path)
File “/srv/homeassistant/lib/python3.5/site-packages/skybellpy/utils.py”, line 17, in load_cache
return pickle.load(handle)
EOFError: Ran out of input
2017-12-01 19:58:44 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of binary_sensor.skybell. Setup failed for dependencies: skybell
2017-12-01 19:58:44 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform binary_sensor.skybell: Could not setup all dependencies.
2017-12-01 19:58:44 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of switch.skybell. Setup failed for dependencies: skybell
2017-12-01 19:58:44 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform switch.skybell: Could not setup all dependencies.
Any suggestions on how to fix this?
