Running Home Assistant 0.80.2 on hass.io - Skybell HD camera broke with the latest update anyone having the same problem?
I don’t think it was the update. I’m still on .76 and I don’t have an image from the camera either.
I have the same issue for a few days. Yes, I don’t think it is the update. No errors…can someone post an issue on Github?
Mine doesn’t work either. It has been a while since I used the Skybell HD within Home Assistant (Hassio). I tested it yesterday on version 0.79.3, but no luck with this.
I also mentioned the problem on Github as suggested [Skybell issue Github Skybell issue @ Github #17617.
Hi all,
I also began experiencing the same issue with 0.80. I’m actually glad I’m not the only one who came up against this situation…
Add me to the list. Running 81.2 but I’ve had issues for much longer.
Not to mention my logs fill with sensor communication issues.
Home Assistant 0.82.0, skybell still not working.
I`m on 0.83.3 and no video from Skybell HD
This is fixed for me in 0.84b4…
Unfortunately, 0.88.2 still has this bug for me.
edit: fixed in 0.89.1
