This is my first post here. I’m new to the home-assistant community, and I’m trying to find out how to debug an issue I’m encountering with SkyConnect. With a cadence of about 2-3 days, the skyconnect for my home assistant green will just stop working entirely. That is, all ikea lights, buttons, and motion sensors stop working, either for automations I’ve set, or for turning on and off things via the home assistant app. Rebooting home-assistant fixes the problem pretty reliably.
I just had this happen again today (the cadence seems to have accelerated to once a day with the previous HA-core release), and so I’m left wondering how to debug and resolve this issue without having to resort to a scheduled reboot of the system.
I’m just using the zigbee mode of skyconnect. I have the home assistant green connected to the dongle via the provided usb cable.
The zigbee channel for skyconnect is 25. If there’s a place to download further logs and diagnostics, let me know and I’ll provide those (in fact, that’s the point of the question, I’m looking for what diagnostics and logs I should peek at).
Yes, I initially did not have the cable, as I didn’t realize what it was for. When I noticed issues, I started using the cable, but no luck. That being said, I do not think this is a problem with the cable. This issue happens at a relatively stable interval, and rebooting the hardware fixes it without fail for a period of time.
Bumping this thread to provide a solution. I read elsewhere that AwoX bulbs are poorly made and create instability in zigbee networks they are part of. I removed the AwoX bulb present in my network, and I haven’t seen this issue again since. There are still some issues with some devices becoming unresponsive after a period of time, but the devices are on the edge of my network with not much routers around, so adding more routers in those areas may help things.
Good find with your setup, make sure to contact the maker of that product to ask them for firmware updates and to test if that resolves the issue with them that you are experiencing at the time and swap to another brand or model in the line that does not have the issue in the mean time.
As for routers you can either get dedicated devices that add to the mesh that don’t do anything else or just use smart plugs or relays in the areas where you want to add power socket control and monitoring anyways.
