I occasionally have the problem that devices in my Zigbee network cannot be reached.
The error is “Failed to deliver message: <sl_Status.ZIGBEE_DELIVERY_FAILED: 3074>”, but that’s not the issue here.
I’ve read that it’s probably an interference issue, but updating the Skyconnect stick has also been recommended in some threads.
The Web-Flasher (Home Assistant Connect ZBT-1) is currently disabled, so I installed this addon and started it: addons/silabs_flasher at master · home-assistant/addons · GitHub
Since then, the stick can no longer be used.
The integration reports an incorrect firmware:
I also see this message:
The view under “Settings > System > Hardware” looks different than described in the message and I can’t set up Zigbee either:
I have been using the Skyconnect stick for more than a year. Apparently with multi-protocol firmware, although I can’t remember having configured this explicitly.
I don’t have a thread device, so I only need Zigbee atm. I use the ZHA integration.
How can I fix the firmware/configuration?
Thank you & best regards!
