I did have some weirdness with the ports so just overrode the ports with whatever is meant to be set:
- EZSP Port: 9999
- OpenThread REST API Port: 8081
Thnx dude for the answer. Now my zigbee is also running again.
- EZSP Port: 9999
So it wasnt working on my VM on my Synology NAS. This week Iāve switched to a NUC, and now its working
where did you make these changes? Which screen to be exact?
I did the changes in the āSilicon Labs Multiprotocolā Add-on.
In that add-on go to configuration.
Scroll all the way down and you will see this:
Even though it looks like the port number is filled in for you (circled in red), it only says that itās the default port number that is used for this.
So actually nothing has been filled in, that is why you have to enter a port number yourself.
Thatās what i did (blue underlined).
After that hit save and it says to restart the add-on and your good to go.
Thank you. I entered the ports. Unfortunately my problem wasnāt resolved, will continue to explore. Thank you
You have to port-forward (open) the specific ports on your router otherwise it will not work.
Please, can you tell me more about this?! Even Nabu Casa support hasnāt been able to solve my issue and port forwarding wasnāt a suggestion from them so Iām willing to try anything.
I know one last thing you can try but you have to figure out yourself because you have to dive into the settings of your router.
