Skyconnect & Portainer
Hi all, after a SD card failure (power outage)
I decided to do a new fresh install using Portainer, I have got everything up and running but have issue that as you can see from the picture no mesh even thought all the switches I have connect are repeater/routers
I was using to sonoff ZBdongle-P without issue on the other system, I thought the skyconnect would be a good move.
any help or advice would be gratefully received.
Screenshot 2024-08-01 191352
Try running container as privileged you see if that changes things
Hi yea already set container as privileged, thanks for input
