When discovering devices via SkyConnect, there is an option to rename the newly discovered entity.
Let’s say a device is automatically named lumi airrtc agl001
. I then rename it to Arbeitszimmer/Vorne
. However, while the friendly_name now is Arbeitszimmer/Vorne
, the ids are still
climate.lumi_lumi_airrtc_agl001_thermostat_2
(should have been renamed toclimate.arbeitszimmer_vorne
orclimate.arbeitszimmer_vorne_thermostat
sensor.lumi_lumi_airrtc_agl001_hvac_action_2
(should have beensensor.arbeitszimmer_hvac_action
sensor.lumi_lumi_airrtc_agl001_battery_2
( →sensor.arbeitszimmer_vorne_battery
Why?
While building automations over the years, I used certain patters, for example, all climate entities are named climate.<room>
, or -if more than one in a room- climate.<room>-<location>
, so climate.kitchen
or climate.office_window
, climate.office_front
, etc.
So when changing automations regarding these devices, I can search and replace climate.kitchen
with climate.office_window
(same for, in this case, for example the binary_sensors for the windows related to the thermostats, as they are also named binary_sensor.kitchen_window_contact
, binary_sensor.office_window_front_contact
, etc.).
These new names are not very transparent; while the thermostat in the kitchen is climate.lumi_lumi_airrtc_agl001_thermostat_2
, the one in the bedroom will be climate.lumi_lumi_airrtc_agl001_thermostat_5
. However, these names are determined by the time they are added. So if I want the window sensor for the bedroom to end with _5
, I also need to add it fifth place (or manually change everything).
I used to write everything in yaml, and now the UI for automations has improved so much. Perhaps, a lot of people don’t even care about this naming system… but I doubt that I am the only person why still prefers yaml and has a naming system for entities… right?
(I am aware that I can manually change the entites as a workaround… but this requires me to rename every single entity an integration proviedes; changing to climate.office_thermostat
will not automatically also change the appropriate battery sensor to sensor.office_battery
