Skyconnect - Unable to add to ZHA or Flash via Webflasher
Hi there,
I just purchased a skyconnect and have run into some issues.
I am running a fresh HA via VM on a QNAP NAS. I plugged in the skyconnect and it is seen by the QNAP. Added it to the VM.
Waiting some time to see if it auto detected and it did not. So I attempted to add ZHA.
ZHA sees the USB.
However if I hit submit it sits there spinning for about 1 min then asks me to pick my radio type. It is then unable to connect to it.
Window states the following:
Failed to connect
Serial Device Path = /dev/ttyUSB0
Port Speed = 115200
I then attempted to update the USB via the webflasher found here Home Assistant SkyConnect
Installed the drivers and it was able to detect it on the correct port. It gives me a spinning logo when I hit submit. After about 20 seconds it displays the following message.
Image removed due to new user rule - It states
Connection failed
The running firmware could not be detected.
Make sure the USB port works and if you are using a USB extension cable, make sure the cable can transfer data. Unplug the Home Assistant SkyConnect and plug it back in to reset and try again.
I have tried this on multiple computers, windows versions and browser. Same result each time. I have also tried multiple versions of the drivers.
I have a silabs flasher log if that is a help.
2024-02-20 00:19:57 emscripten universal_silabs_flasher.flasher[42] INFO Probing ApplicationType.GECKO_BOOTLOADER at 115200 baud
2024-02-20 00:19:57 emscripten zigpy.serial[42] DEBUG Opening a serial connection to '/dev/webserial' (115200 baudrate)
2024-02-20 00:19:57 emscripten universal_silabs_flasher.common[42] DEBUG Connection made: <webserial_transport.WebSerialTransport object at 0x13558e8>
2024-02-20 00:19:57 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'3'
2024-02-20 00:19:59 emscripten webserial_transport[42] DEBUG Closing serial port
2024-02-20 00:19:59 emscripten universal_silabs_flasher.flasher[42] INFO Probing ApplicationType.CPC at 460800 baud
2024-02-20 00:19:59 emscripten zigpy.serial[42] DEBUG Opening a serial connection to '/dev/webserial' (460800 baudrate)
2024-02-20 00:19:59 emscripten webserial_transport[42] DEBUG Closed serial port
2024-02-20 00:19:59 emscripten universal_silabs_flasher.common[42] DEBUG Connection made: <webserial_transport.WebSerialTransport object at 0x1b37d18>
2024-02-20 00:19:59 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 00:19:59 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 00:20:00 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 1 of 4)
2024-02-20 00:20:00 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 00:20:00 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 00:20:01 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 2 of 4)
2024-02-20 00:20:02 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 00:20:02 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 00:20:03 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 3 of 4)
2024-02-20 00:20:03 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 00:20:03 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 00:20:04 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 4 of 4)
2024-02-20 00:20:04 emscripten webserial_transport[42] DEBUG Closing serial port
2024-02-20 00:20:04 emscripten universal_silabs_flasher.flasher[42] INFO Probing ApplicationType.CPC at 115200 baud
2024-02-20 00:20:04 emscripten zigpy.serial[42] DEBUG Opening a serial connection to '/dev/webserial' (115200 baudrate)
2024-02-20 00:20:04 emscripten webserial_transport[42] DEBUG Closed serial port
2024-02-20 00:20:04 emscripten universal_silabs_flasher.common[42] DEBUG Connection made: <webserial_transport.WebSerialTransport object at 0x155f008>
2024-02-20 00:20:04 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 00:20:04 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 00:20:05 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 1 of 4)
2024-02-20 00:20:05 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 00:20:05 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 00:20:06 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 2 of 4)
2024-02-20 00:20:06 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 00:20:06 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 00:20:07 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 3 of 4)
2024-02-20 00:20:07 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 00:20:07 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 00:20:08 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 4 of 4)
2024-02-20 00:20:08 emscripten webserial_transport[42] DEBUG Closing serial port
2024-02-20 00:20:08 emscripten universal_silabs_flasher.flasher[42] INFO Probing ApplicationType.CPC at 230400 baud
2024-02-20 00:20:08 emscripten zigpy.serial[42] DEBUG Opening a serial connection to '/dev/webserial' (230400 baudrate)
2024-02-20 00:20:08 emscripten webserial_transport[42] DEBUG Closed serial port
2024-02-20 00:20:08 emscripten universal_silabs_flasher.common[42] DEBUG Connection made: <webserial_transport.WebSerialTransport object at 0x1235be0>
2024-02-20 00:20:08 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 00:20:08 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 00:20:09 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 1 of 4)
2024-02-20 00:20:09 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 00:20:09 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 00:20:10 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 2 of 4)
2024-02-20 00:20:10 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 00:20:10 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 00:20:11 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 3 of 4)
2024-02-20 00:20:12 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 00:20:12 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 00:20:13 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 4 of 4)
2024-02-20 00:20:13 emscripten webserial_transport[42] DEBUG Closing serial port
2024-02-20 00:20:13 emscripten universal_silabs_flasher.flasher[42] INFO Probing ApplicationType.EZSP at 115200 baud
2024-02-20 00:20:13 emscripten zigpy.serial[42] DEBUG Opening a serial connection to '/dev/webserial' (115200 baudrate)
2024-02-20 00:20:13 emscripten webserial_transport[42] DEBUG Closed serial port
2024-02-20 00:20:13 emscripten bellows.ezsp[42] DEBUG Resetting EZSP
2024-02-20 00:20:13 emscripten bellows.uart[42] DEBUG Resetting ASH
2024-02-20 00:20:13 emscripten bellows.uart[42] DEBUG Sending: b'1ac038bc7e'
2024-02-20 00:20:18 emscripten bellows.uart[42] DEBUG Connection lost: None
2024-02-20 00:20:18 emscripten bellows.uart[42] DEBUG Closed serial connection
2024-02-20 00:20:18 emscripten universal_silabs_flasher.flasher[42] INFO Probing ApplicationType.SPINEL at 460800 baud
2024-02-20 00:20:18 emscripten zigpy.serial[42] DEBUG Opening a serial connection to '/dev/webserial' (460800 baudrate)
2024-02-20 00:20:18 emscripten webserial_transport[42] DEBUG Closing serial port
2024-02-20 00:20:18 emscripten webserial_transport[42] DEBUG Closed serial port
2024-02-20 00:20:18 emscripten universal_silabs_flasher.common[42] DEBUG Connection made: <webserial_transport.WebSerialTransport object at 0x1b9bd00>
2024-02-20 00:20:18 emscripten universal_silabs_flasher.spinel[42] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2024-02-20 00:20:18 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'~\x83\x02\x02\xe65~'
2024-02-20 00:20:19 emscripten universal_silabs_flasher.spinel[42] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 1 of 4)
2024-02-20 00:20:19 emscripten universal_silabs_flasher.spinel[42] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2024-02-20 00:20:19 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'~\x83\x02\x02\xe65~'
2024-02-20 00:20:20 emscripten universal_silabs_flasher.spinel[42] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 2 of 4)
2024-02-20 00:20:20 emscripten universal_silabs_flasher.spinel[42] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2024-02-20 00:20:20 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'~\x83\x02\x02\xe65~'
2024-02-20 00:20:21 emscripten universal_silabs_flasher.spinel[42] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 3 of 4)
2024-02-20 00:20:21 emscripten universal_silabs_flasher.spinel[42] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2024-02-20 00:20:21 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'~\x83\x02\x02\xe65~'
2024-02-20 00:20:22 emscripten universal_silabs_flasher.spinel[42] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 4 of 4)
2024-02-20 00:20:22 emscripten webserial_transport[42] DEBUG Closing serial port
2024-02-20 00:20:22 emscripten webserial_transport[42] DEBUG Closed serial port
2024-02-20 18:42:17 emscripten universal_silabs_flasher.flasher[42] INFO Probing ApplicationType.GECKO_BOOTLOADER at 115200 baud
2024-02-20 18:42:17 emscripten zigpy.serial[42] DEBUG Opening a serial connection to '/dev/webserial' (115200 baudrate)
2024-02-20 18:42:17 emscripten universal_silabs_flasher.common[42] DEBUG Connection made: <webserial_transport.WebSerialTransport object at 0x1b552e8>
2024-02-20 18:42:17 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'3'
2024-02-20 18:42:19 emscripten webserial_transport[42] DEBUG Closing serial port
2024-02-20 18:42:19 emscripten universal_silabs_flasher.flasher[42] INFO Probing ApplicationType.CPC at 460800 baud
2024-02-20 18:42:19 emscripten zigpy.serial[42] DEBUG Opening a serial connection to '/dev/webserial' (460800 baudrate)
2024-02-20 18:42:19 emscripten webserial_transport[42] DEBUG Closed serial port
2024-02-20 18:42:20 emscripten universal_silabs_flasher.common[42] DEBUG Connection made: <webserial_transport.WebSerialTransport object at 0x1b93898>
2024-02-20 18:42:20 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 18:42:20 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 18:42:21 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 1 of 4)
2024-02-20 18:42:21 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 18:42:21 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 18:42:22 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 2 of 4)
2024-02-20 18:42:22 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 18:42:22 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 18:42:23 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 3 of 4)
2024-02-20 18:42:23 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 18:42:23 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 18:42:24 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 4 of 4)
2024-02-20 18:42:24 emscripten webserial_transport[42] DEBUG Closing serial port
2024-02-20 18:42:24 emscripten universal_silabs_flasher.flasher[42] INFO Probing ApplicationType.CPC at 115200 baud
2024-02-20 18:42:24 emscripten zigpy.serial[42] DEBUG Opening a serial connection to '/dev/webserial' (115200 baudrate)
2024-02-20 18:42:24 emscripten webserial_transport[42] DEBUG Closed serial port
2024-02-20 18:42:24 emscripten universal_silabs_flasher.common[42] DEBUG Connection made: <webserial_transport.WebSerialTransport object at 0x1c47040>
2024-02-20 18:42:24 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 18:42:24 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 18:42:25 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 1 of 4)
2024-02-20 18:42:25 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 18:42:25 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 18:42:26 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 2 of 4)
2024-02-20 18:42:26 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 18:42:26 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 18:42:27 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 3 of 4)
2024-02-20 18:42:27 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 18:42:27 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 18:42:28 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 4 of 4)
2024-02-20 18:42:28 emscripten webserial_transport[42] DEBUG Closing serial port
2024-02-20 18:42:28 emscripten universal_silabs_flasher.flasher[42] INFO Probing ApplicationType.CPC at 230400 baud
2024-02-20 18:42:28 emscripten zigpy.serial[42] DEBUG Opening a serial connection to '/dev/webserial' (230400 baudrate)
2024-02-20 18:42:28 emscripten webserial_transport[42] DEBUG Closed serial port
2024-02-20 18:42:28 emscripten universal_silabs_flasher.common[42] DEBUG Connection made: <webserial_transport.WebSerialTransport object at 0x1be8338>
2024-02-20 18:42:28 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 18:42:28 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 18:42:29 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 1 of 4)
2024-02-20 18:42:29 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 18:42:29 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 18:42:30 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 2 of 4)
2024-02-20 18:42:31 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 18:42:31 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 18:42:32 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 3 of 4)
2024-02-20 18:42:32 emscripten universal_silabs_flasher.cpc[42] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2024-02-20 18:42:32 emscripten universal_silabs_flasher.common[42] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2024-02-20 18:42:33 emscripten universal_silabs_flasher.cpc[42] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 4 of 4)
2024-02-20 18:42:33 emscripten webserial_transport[42] DEBUG Closing serial port
2024-02-20 18:42:33 emscripten universal_silabs_flasher.flasher[42] INFO Probing ApplicationType.EZSP at 115200 baud
2024-02-20 18:42:33 emscripten zigpy.serial[42] DEBUG Opening a serial connection to '/dev/webserial' (115200 baudrate)
2024-02-20 18:42:33 emscripten webserial_transport[42] DEBUG Closed serial port
2024-02-20 18:42:33 emscripten bellows.ezsp[42] DEBUG Resetting EZSP
2024-02-20 18:42:33 emscripten bellows.uart[42] DEBUG Resetting ASH
2024-02-20 18:42:33 emscripten bellows.uart[42] DEBUG Sending: b'1ac038bc7e'
2024-02-20 18:42:40 emscripten bellows.uart[42] DEBUG Connection lost: None
2024-02-20 18:42:40 emscripten bellows.uart[42] DEBUG Closed serial connection
2024-02-20 18:42:40 emscripten universal_silabs_flasher.flasher[42] INFO Probing ApplicationType.SPINEL at 460800 baud
2024-02-20 18:42:40 emscripten zigpy.serial[42] DEBUG Opening a serial connection to '/dev/webserial' (460800 baudrate)
2024-02-20 18:42:41 emscripten webserial_transport[42] DEBUG Closing serial port
2024-02-20 18:42:41 emscripten webserial_transport[42] DEBUG Closed serial port
Is there anything obviously wrong or have I possibly got a dud?
I’ve sent the device back. Will try another one.
It was indeed that the device was DOA.
Replacement device worked instantly.
