So I have HA installed through docker. I plugged in the new SkyConnect that came in and chose to add integration. It gives me a list of radio types but don’t know which to hit. I included a screenshot here.
I read somewhere that it won’t be plug in play when using docker and you have to add it. So I re-deployed the image via portainer adding “host: /dev/ttyUSB0 and container: /dev/ttyUSB0” to the add device option and replaced the old container with it. Then I tried again and before asking about the radios it showed that, which I chose, and then it led back to the same radio types.
Then I remembered I had to do something similar for the zwave dongle via its container. I realized it was using “/dev/serial/by-id/” with the name of the device after as listed in file manager. So I did the same with /dev/serial/by-id/usb-Nabu_Casa_SkyConnect_v1.0_…yatta yatta yatta-port-0 and with /dev/skyconnect under container. I then tried integrating again and it skipped right to the radio list and still no SkyConnect is listed.
Nothing shows up in the logs or anywhere else. Am I doing things right?
I really don’t know the answer to your question, but from my research, the SkyConnect has the SiLabs EFR32MG21, and the Zigbee stack for this device is EZSP.
Same - migration fails at the end regardless of what I chose “Failed to connect” even though the USB path is correct. I tried ezsp and the default - made no difference. If you get this migration to work I would like to know the resolution.
I finally gave up and migrated my install from a docker install to Home Assistant OS installed on a second mini PC. SkyConnect came right up when I inserted it after that. Only thing that I kind of got dinged on was my Z-Wave stick. It works and everything was recognized but my zoOZ water leak sensor shows as Node 3 and reacts differently in automations with diff values so just need to figure out how to use it as a trigger now. Could have been worse.
I’m on a rpi4, most of my system is on zwave, two years old installation, just plugged in the skyconnect and then selected add integration " Zigbee Home Automation"
First time, only usb0:usb0 path showed, tried a few more times, then Skyconnect showed. Selected it and pressed continue, came to the screen shown above where to set port speed etc, tried a few times, failed every time.
Tried a to install “Zigbee Home Automation” for a 10th time or something, then it just worked.
Not much of an advise really, but just try again a few times and eventually it just works. I didnt reboot, didnt change any hardware, didnt leave the integration screen… Just tried until it got tired and accepted haha
