I had a conbee stick 2 as my Zigbee connector which was ok however as my network grew the connection often failed. So after some reading up i upgraded to a Skyconnect. this was awesome everything worked better, for a few weeks! then suddenly the integration failed to start. I worked out that its started to clash with my TP link Deco’s as if tell the deco app to check the network it reports a busy frequency then optimizes the network. Everything then starts to work, for a matter of minutes. I have tried changing te Zigbee channel 3 or 4 times but they never work! I dont have an option to change the WIFI channel as Deco dont give you the option.
Does anyone have thoughts/ideas that i could try?
