im trying to use my ZBT-1 following this “getting started”: Home Assistant Connect ZBT-1
but when plugging in the dognle and using the pop-up in HA, i can select “Thread” (like in step 3 of the “getting started”) and be greeted with a “unsuported_firmware” dialog.
step 2 of “getting started” is not available, i only see cpu and ram under “hardware”
I am in the same boat. Just got the zbt-1. Used the web update to flash the thread firmware but its not showing in the hardware. @Jonny0815 Did you get this sorted?
As a note, im using the docker version running on Unraid.
