Hi guys
I have read other threads here related to the topic but found no one explicitly touching this.
Is there a way to use some of the Skydance wall mounted DMX512 master panels (like this one Touch Panel 4 Zone RGB DMX512 Master & RF Remote T13 ) and let Home Assistant read its output? So the wall mounted panel would send DMX512 command to HomeAssistant (directly or with help of Nodered or anyhow) and HA would set the properties of the chosen light appropriately and then HA would control the lights (in a proper way depending of the light type). So the Skydance panel would not control any lights directly but it would serve the same purpose as if you control the color/brightness/etc. of the light in Lovelace. Or other ways than through DMX512 as Skydance produces also RF and WiFi ones. Thx.
Did you find a solution then?,
wanting to do something similar
