The slack component has begun spamming my logs with read timeouts. However the messages send just fine. Any thoughts on how to fix this? Makes tracking down other issues hard.
2018-05-07 19:17:16 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall notify.slacknotify: data=file=url=http://192.168.53.112/snap.jpeg, message=<homeassistant.helpers.template.Template object at 0x7fde206ee5c0>>
File "/usr/local/lib/python3.5/dist-packages/urllib3/connectionpool.py", line 387, in _make_request
six.raise_from(e, None)
File "<string>", line 2, in raise_from
File "/usr/local/lib/python3.5/dist-packages/urllib3/connectionpool.py", line 383, in _make_request
httplib_response = conn.getresponse()
File "/usr/lib/python3.5/http/client.py", line 1198, in getresponse
response.begin()
File "/usr/lib/python3.5/http/client.py", line 297, in begin
version, status, reason = self._read_status()
File "/usr/lib/python3.5/http/client.py", line 258, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/lib/python3.5/socket.py", line 576, in readinto
return self._sock.recv_into(b)
File "/usr/lib/python3.5/ssl.py", line 937, in recv_into
return self.read(nbytes, buffer)
File "/usr/lib/python3.5/ssl.py", line 799, in read
return self._sslobj.read(len, buffer)
File "/usr/lib/python3.5/ssl.py", line 583, in read
v = self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
File "/usr/local/lib/python3.5/dist-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/usr/local/lib/python3.5/dist-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.5/dist-packages/urllib3/util/retry.py", line 357, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.5/dist-packages/urllib3/packages/six.py", line 686, in reraise
raise value
File "/usr/local/lib/python3.5/dist-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.5/dist-packages/urllib3/connectionpool.py", line 389, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/local/lib/python3.5/dist-packages/urllib3/connectionpool.py", line 309, in _raise_timeout
raise ReadTimeoutError(self, url, "Read timed out. (read timeout=%s)" % timeout_value)
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='slack.com', port=443): Read timed out. (read timeout=10)
File "/usr/local/lib/python3.5/dist-packages/homeassistant/core.py", line 1002, in _event_to_service_call
await service_handler.func(service_call)
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/notify/__init__.py", line 137, in async_notify_message
yield from notify_service.async_send_message(**kwargs)
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/notify/slack.py", line 127, in send_message
files={'file': file_as_bytes})
File "/root/.homeassistant/deps/lib/python3.5/site-packages/slacker/__init__.py", line 123, in post
api, **kwargs
File "/root/.homeassistant/deps/lib/python3.5/site-packages/slacker/__init__.py", line 94, in _request
**kwargs)
File "/usr/local/lib/python3.5/dist-packages/requests/api.py", line 112, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.5/dist-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.5/dist-packages/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.5/dist-packages/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.5/dist-packages/requests/adapters.py", line 521, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='slack.com', port=443): Read timed out. (read timeout=10)
That message did in-fact send though:
Any thoughts? Should I open an issue on Github for this?
