Slae.sh cc2652rb zigbee stick, ZHA not starting
I ordered and actually received the slae.sh stick. I installed it in my Pi4 running HASS (2021.10.6), and restarted the server. The stick was found and configured successfully. However, ZHA won’t start. I’m getting 2 errors and 2 warnings. The cc2652rb stick is flashed with the latest firmaware, 20210708.
Config entry 'slae.sh cc2652rb stick - s - /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_3A_77-if00-port0, s/n: 00_12_4B_00_23_93_3A_77 - Silicon Labs - 10C4:EA60' for zha integration not ready yet; Retrying in background
2:59:27 PM – (WARNING) config_entries.py
Couldn't start ZNP = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2 coordinator
2:59:27 PM – (ERROR) Zigbee Home Automation
Couldn't start application
2:59:27 PM – (ERROR) /usr/local/lib/python3.9/site-packages/zigpy/application.py
Received an unhandled command: ZDO.MgmtPermitJoinReq.Rsp(Status=<Status.NWK_INVALID_REQUEST: 194>)
2:59:12 PM – (WARNING) /usr/local/lib/python3.9/site-packages/zigpy_znp/api.py
Full log below:
2021-10-25 14:59:12 WARNING (MainThread) [zigpy_znp.api] Received an unhandled command: ZDO.MgmtPermitJoinReq.Rsp(Status=<Status.NWK_INVALID_REQUEST: 194>)
2021-10-25 14:59:27 ERROR (MainThread) [zigpy.application] Couldn't start application
2021-10-25 14:59:27 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start ZNP = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2 coordinator
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/api.py", line 395, in request
response = await response_future
asyncio.exceptions.CancelledError
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 152, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.9/site-packages/zigpy/application.py", line 69, in new
await app.startup(auto_form)
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/zigbee/application.py", line 196, in startup
return await self._startup(
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/zigbee/application.py", line 209, in _startup
await znp.connect()
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/api.py", line 116, in connect
self.capabilities = (await self.request(c.SYS.Ping.Req())).Capabilities
File "/usr/local/lib/python3.9/site-packages/async_timeout/__init__.py", line 55, in __aexit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.9/site-packages/async_timeout/__init__.py", line 92, in _do_exit
raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
2021-10-25 14:59:27 WARNING (MainThread) [homeassistant.config_entries] Config entry 'slae.sh cc2652rb stick - s - /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_3A_77-if00-port0, s/n: 00_12_4B_00_23_93_3A_77 - Silicon Labs - 10C4:EA60' for zha integration not ready yet; Retrying in background
2021-10-25 14:59:50 ERROR (MainThread) [zigpy.application] Couldn't start application
2021-10-25 14:59:50 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start ZNP = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2 coordinator
await znp.connect()
