Slaeshs cc2652rb stick doesnt seem to work with Zigbee2MQTT after homeassistant update
After Update to Home Assistant 2023.9.2 and Operating System 10.5 my slaeshs cc2652rb stick doesnt seem to work on my Synology DiskStation DS218+ with DSM 6.2.4-25556.
Log with activated zigbee_herdsman_debug says:
[21:10:53] INFO: Preparing to start...
[21:10:54] INFO: Socat not enabled
[21:10:54] INFO: Zigbee Herdsman debug logging enabled
[21:10:56] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:debug 2023-09-18 21:11:07: Loaded state from file /config/zigbee2mqtt/state.json
Zigbee2MQTT:info  2023-09-18 21:11:07: Logging to console and directory: '/config/zigbee2mqtt/log/2023-09-18.21-11-06' filename: log.txt
Zigbee2MQTT:debug 2023-09-18 21:11:07: Removing old log directory '/config/zigbee2mqtt/log/2023-09-17.13-57-46'
Zigbee2MQTT:info  2023-09-18 21:11:07: Starting Zigbee2MQTT version 1.33.0 (commit #unknown)
Zigbee2MQTT:info  2023-09-18 21:11:07: Starting zigbee-herdsman (0.18.5)
Zigbee2MQTT:debug 2023-09-18 21:11:07: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/config/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","databasePath":"/config/zigbee2mqtt/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"path":"/dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_22_98_94_AE-if00-port0"}}'
2023-09-18T19:11:08.092Z zigbee-herdsman:adapter Failed to validate path: 'Error: spawn udevadm ENOENT'
2023-09-18T19:11:08.099Z zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11]},"serialPort":{"path":"/dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_22_98_94_AE-if00-port0"},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json","adapter":{"disableLED":false,"concurrent":null,"delay":null}}'
2023-09-18T19:11:08.103Z zigbee-herdsman:adapter:zStack:znp:log Opening SerialPort with {"path":"/dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_22_98_94_AE-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
2023-09-18T19:11:08.127Z zigbee-herdsman:adapter:zStack:znp:log Serialport opened
2023-09-18T19:11:08.133Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
2023-09-18T19:11:08.139Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
2023-09-18T19:11:08.397Z zigbee-herdsman:adapter:zStack:znp:log Writing CC2530/CC2531 skip bootloader payload
2023-09-18T19:11:08.403Z zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
2023-09-18T19:11:09.408Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
2023-09-18T19:11:09.409Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
2023-09-18T19:11:09.663Z zigbee-herdsman:adapter:zStack:znp:log Skip bootloader for CC2652/CC1352
2023-09-18T19:11:10.133Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
2023-09-18T19:11:10.134Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
2023-09-18T19:11:11.706Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,6,65,128,0,2,1,2,7,1,192]
2023-09-18T19:11:11.709Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,6,65,128,0,2,1,2,7,1,192]
2023-09-18T19:11:11.711Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 6 - 2 - 1 - 128 - [0,2,1,2,7,1] - 192
2023-09-18T19:11:11.717Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- SYS - resetInd - {"reason":0,"transportrev":2,"productid":1,"majorrel":2,"minorrel":7,"hwrev":1}
2023-09-18T19:11:11.720Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-09-18T19:11:16.138Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
2023-09-18T19:11:16.142Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
2023-09-18T19:11:22.152Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
2023-09-18T19:11:22.155Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
Zigbee2MQTT:error 2023-09-18 21:11:28: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-09-18 21:11:28: Failed to start zigbee
Zigbee2MQTT:error 2023-09-18 21:11:28: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-09-18 21:11:28: Exiting...
Zigbee2MQTT:error 2023-09-18 21:11:28: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
    at Zigbee.start (/app/lib/zigbee.ts:60:27)
    at Controller.start (/app/lib/controller.ts:101:27)
    at start (/app/index.js:107:5)
  • I have already updated the stick to the current version but nothing changes.
  • ZHA is uninstalled.
Maybe @slaesh has a hint, or is it a problem with the new homeassistant version?
Addition: If I activate ZHA, everything works without problems!
