Sleep as Android: Trigger app actions
Send commands to the Sleep as Android app on your selected mobile device via Home Assistant. Requires the device to run the official Home Assistant companion app.
blueprint:
  name: "Sleep as Android: Trigger app actions"
  description: >
  domain: script
  author: tr4nt0r
  input:
    notify_device:
      description: >
        The mobile device running Sleep as Android. Must have the official
        Home Assistant companion app installed and connected.
      selector:
        device:
          filter:
            - integration: mobile_app
          multiple: false
    sleep_action:
      description: >
        The specific Sleep as Android command to trigger
      selector:
        select:
          options:
            - label: Start sleep tracking
              value: com.urbandroid.sleep.alarmclock.START_SLEEP_TRACK
            - label: Start sleep tracking + Set an alarm for ideal sleep length
              value: com.urbandroid.sleep.alarmclock.START_SLEEP_TRACK_WITH_IDEAL_ALARM_ACTION
            - label: Stop sleep tracking
              value: com.urbandroid.sleep.alarmclock.STOP_SLEEP_TRACK
            - label: Pause sleep tracking for 5 minutes
              value: com.urbandroid.sleep.ACTION_PAUSE_TRACKING
            - label: Snooze alarm
              value: com.urbandroid.sleep.alarmclock.ALARM_SNOOZE
            - label: Dismiss alarm
              value: com.urbandroid.sleep.alarmclock.ALARM_DISMISS_CAPTCHA
            - label: Stop lullaby
              value: com.urbandroid.sleep.ACTION_LULLABY_STOP_PLAYBACK
            - label: Request backup
              value: com.urbandroid.sleep.REQUEST_SYNC
            - label: Change alarm state (when not currently ringing)
              value: com.urbandroid.sleep.alarmclock.ALARM_STATE_CHANGE
    section_extra_snooze_time:
      name: Snooze alarm extras
      icon: mdi:alarm-snooze
      collapsed: true
      input:
        extra_snooze_time:
          name: Extra snooze time (optional)
          description: >
            Override the snooze duration for this alarm (1–60 minutes).
            Leave blank to use the default snooze time set in the Sleep as Android app.
          selector:
            number:
              min: 1
              max: 60
              unit_of_measurement: minutes
              mode: box
          default: ""
    section_alarm_state_change:
      name: Change alarm state extras
      icon: mdi:alarm
      description: These settings are required when using the "Change alarm state" action.
      collapsed: true
      input:
        alarm_label:
          description: >
            The label of the alarm to modify.
            Must explicitly set **in the Sleep as Android app** for this action to work.
            If multiple alarms share this label, only one will be changed (no guarantee which).
          selector:
            text:
          default: "Alarm"
        alarm_state:
          name: Enable or disable
          description: >
            Select whether the specified alarm should be turned on (enabled) or
            turned off (disabled).
          selector:
            boolean:
          default: false
    section_start_in_battery_saving_mode:
      name: Start sleep tracking extras
      icon: mdi:record-rec
      collapsed: true
      input:
          name: Start in battery saving mode
          description: Start sleep tracking with reduced power usage to save battery.
          selector:
            boolean:
          default: false
mode: parallel
sequence:
  - variables:
      sleep_action: !input sleep_action
      alarm_label: !input alarm_label
      alarm_state: !input alarm_state
      extra_snooze_time: !input extra_snooze_time
      start_in_battery_saving_mode: !input start_in_battery_saving_mode
  - alias: Send intent to Sleep as Android
    domain: mobile_app
    type: notify
    device_id: !input notify_device
    message: command_broadcast_intent
      intent_package_name: com.urbandroid.sleep
      intent_action: !input sleep_action
      intent_extras: >-
        {% if sleep_action == 'com.urbandroid.sleep.alarmclock.ALARM_STATE_CHANGE' and alarm_label %}
          alarm_label:{{ alarm_label }},alarm_enabled:{{ alarm_state }}
        {% elif sleep_action == 'com.urbandroid.sleep.alarmclock.ALARM_SNOOZE' and extra_snooze_time %}
          extra_snooze_time:{{ extra_snooze_time }}
        {% elif sleep_action == 'com.urbandroid.sleep.alarmclock.START_SLEEP_TRACK' and start_in_battery_saving_mode %}
          START_IN_BATTERY_SAVING_MODE:true
        {% endif %}
Hey @tr4nt0r thank you for creating this integration. Do you plan to release a blueprint using the Sleep as Android events as triggers? Something that would easily allow a user to specify actions to take when the alarm starts, is dismissed, etc.?
No, I don’t have any plans for such a blueprint. The events can easily be added as triggers to automations and the actions could be pretty much anything. You can find an example automation in the Sleep as Android the documentation,, as you can see it is quite simple and uncomplicated
Hi, I think I’m missing something. I’ve been trying to use this, my phone does show a notification but nothing happens in sleep as android while the intent api option is on. How can I try to debug this ?
Replying to myself, solution was:
Settings > companion app > select your server
Turn on control remotely
What might the implementation of extra_snooze_time look like? I see no way in Home Assistant of getting the amount of time that was snoozed (to add “extra” to it), nor a way of altering a snooze duration once it’s set.
