bachya
(Aaron Bach)
December 17, 2020, 12:31am
1
This blueprint takes an input_number and a timer to create a sleep timer! The user can configure:
The action(s) that should occur when the timer starts
The action(s) that should occur when the timer expires
The action(s) that should occur when the timer is canceled
Note that the unit of measurement on the input_number defaults to minutes.
blueprint:
description: Perform one or more actions after a sleep timer expires
domain: automation
input:
input_number:
description: The input number that determines how many minutes
the sleep timer should last for
selector:
entity:
domain: input_number
timer:
description: The entity that represents the timer itself
selector:
entity:
domain: timer
timer_cancel_action:
name: Action on Timer Cancel
description: The action(s) to run when the timer is canceled
default: []
selector:
action: {}
timer_expire_action:
name: Action on Timer Expire
description: The action(s) to run when the timer expires
default: []
selector:
action: {}
timer_start_action:
name: Action on Timer Start
description: The action(s) to run when the timer starts
default: []
selector:
action: {}
mode: restart
variables:
slider: !input input_number
slider_value: "{{ states(slider) | int * 60 }}"
- platform: state
entity_id: !input input_number
- platform: state
entity_id: !input timer
to: idle
choose:
# 1. The timer expires:
- conditions:
- condition: template
value_template: >
{{ trigger.to_state.state == "idle" }}
sequence:
- service: input_number.set_value
value: 0
- choose: []
default: !input timer_expire_action
# 2. The timer is canceled:
- conditions:
- condition: numeric_state
below: 1
sequence:
- service: timer.cancel
- choose: []
default: !input timer_cancel_action
# 3. The timer is started:
- conditions:
above: 0
sequence:
- service: timer.start
duration: "{{ slider_value }}"
- choose: []
default: !input timer_start_action
Hey dont get it working :frowning
just the “Start” procedure works for me.
Following automation made with the assistant:
- id: '1615771078429'
alias: Sleep Timer
description: ''
use_blueprint:
path: bachya/sleep-timer.yaml
input:
input_number: input_number.sleeptimer
timer: timer.sleep
- service: switch.toggle
entity_id: switch.smartplug
- type: turn_off
device_id: db88ee791536077bdeac580ddad761cf
entity_id: light.luester
domain: light
timer_start_action:
- type: turn_on
domain: light
brightness_pct: 50
I added a timer and a input with the helper:
Sleep timer.sleep Timer
Sleeptimer input_number.sleeptimer Nummer
I also tried this with adding the timer in the config and the input number in the inpt_number.yaml Added a new Automation with the assistant, but Same Problem.
Any Idea?
Regards
Hey,
so i found my mistake:
made a “min” with the input. I made 5 minutes min, because I never need a timer less then 5 minutes.
When i cancel the timer, the expired action runs too. Wasnt expecting this.
The rest works fine now, THX for your work!
Ctyd
(Karl koch)
March 16, 2021, 12:39am
4
Nice blueprint, works for me, now the TV shutdown automatically and dont run Till the morning When i wakeup
kkoouu
(Kkoouu)
March 18, 2021, 4:36pm
5
Thanks for this, but:
I just don’t understand why the actions that should be performed when timer expires are executed when the time is cancelled as well.
kkoouu
(Kkoouu)
March 18, 2021, 8:23pm
6
I finally solved it by using this blueprint automation just to start the timer with no actions.
Then I created another automation in UI with trigger:
Trigger Type: Event
Event type: timer.finished
Event data: entity_id: timer.<timer_name>
This one is triggered only when timer is finished, not cancelled.
kkoouu
i have the same problem. I guess its something with the “0” and “1” if. They seem to be wrong. But im new here and wasnt able to check. My heating controlling was more important for me.
kkoouu
(Kkoouu)
March 19, 2021, 5:26pm
8
everything in computers have something to do with 0 and 1
You can test my workaround, it’s working fine I will try to review original blueprint later …
mkono87
(Mike)
September 29, 2021, 12:18am
9
Not sure whats going on but even though the timer seems to work correctly, when the timer expires and go to idle and get this error and my automation doesnt work ie. turn off tv
2021-09-28 20:10:49 ERROR (MainThread) [homeassistant.components.automation.sleep_timer] Sleep Timer: Choose at step 1: choice 1: Error executing script. Invalid data for call_service at pos 1: Invalid value for input_number.sleep_timer_duration: 0.0 (range 10.0 - 30.0)
2021-09-28 20:10:49 ERROR (MainThread) [homeassistant.components.automation.sleep_timer] Sleep Timer: Error executing script. Invalid data for choose at pos 1: Invalid value for input_number.sleep_timer_duration: 0.0 (range 10.0 - 30.0)
2021-09-28 20:10:49 ERROR (MainThread) [homeassistant.components.automation.sleep_timer] Error while executing automation automation.sleep_timer: Invalid value for input_number.sleep_timer_duration: 0.0 (range 10.0 - 30.0)
bachya
(Aaron Bach)
September 29, 2021, 12:57am
10
That seems to indicate that your input_numbers have a min of 10 and a max of 30; a value of 0 won’t work there.
mkono87
(Mike)
September 29, 2021, 1:06am
11
The initial is 10 and I tried min 5 and max 30 and still the same issue.
Checked the trace and yeah it think i chose 0
choose:
- conditions:
value_template: |
sequence:
entity_id: input_number.sleep_timer_duration
value: 0
It weird that it shooting the error after the timer completes when that type of error should throw at the start. Either way, it doesnt allow the action to continue. Il have to try to do it manually instead.
