Sleepiq integration or maybe flow knowledge
Greetings all, So this might be a very simple question, it is about where to find information in HA. I just went and added my sleepiq to my configuration.yaml and the only options I had were:
sleepiq: username: YOUR_USERNAME password: YOUR_PASSWORD
I filled it out, checked my configureation and restarted
but I get a message on the left side that says: The following integrations and platforms could not be set up:
when checking the log I see it says:
2020-03-07 08:40:28 ERROR (SyncWorker_18) [homeassistant.components.sleepiq]
SleepIQ failed to login, double check your username and password"
2020-03-07 08:40:29 ERROR (MainThread) [homeassistant.setup] Setup failed for sleepiq: Integration failed to initialize.
I have validated the username and password are correct by going to https://www.sleepnumber.com/ and logging in successfully. I even added quotes and double quotes to the entries in the configuration file.
Google has not been my friend on this one, so decided to come here.
on the sleepiq HA page (https://www.home-assistant.io/integrations/sleepiq/), it is very limited in the information that it gives so I am thinking I might be missing something
I am fairly new to Home Assistant and it just might be that I am missing some part of the configuration flow… if that is the case I would ask if you can point me in a direction that might get me better educated (watching lots of Youtube videos for sure)
So I got this up and running, apparently the username and password for the main sight and the sleepiq site were different
