I was just wondering if someone could take a look at logs of my Home Assistant device. I have two door window ZigBee sensor and both are disconnecting randomly without any logs/errors.
From the logs, It seems like it’s trying to re-join but no response from host and it’s simply saying "[zigpy.application] Skip initialization for existing device 00:0d:6f:00:0b:d1:4a:cc"
Here is details
Device info ( CEL EM357 )
MCT-340 SMA
by Visonic
Zigbee Coordinator
Firmware: 0x00000720
Below logs keep reapeating when i open/close door window sensors
2021-06-11 21:18:53 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame 241 (readCounters) received: b'0500340009000b0003000000040002000b0006000a0005000300000000000000050000000000000000000000000000000000000000000000000000000000000002000000000000000000000000000000'
2021-06-11 21:18:53 DEBUG (MainThread) [bellows.zigbee.application] EZSP Counters: COUNTER_MAC_RX_BROADCAST: 5,COUNTER_MAC_TX_BROADCAST: 52,COUNTER_MAC_RX_UNICAST: 9,COUNTER_MAC_TX_UNICAST_SUCCESS: 11,COUNTER_MAC_TX_UNICAST_RETRY: 3,COUNTER_MAC_TX_UNICAST_FAILED: 0,COUNTER_APS_DATA_RX_BROADCAST: 4,COUNTER_APS_DATA_TX_BROADCAST: 2,COUNTER_APS_DATA_RX_UNICAST: 11,COUNTER_APS_DATA_TX_UNICAST_SUCCESS: 6,COUNTER_APS_DATA_TX_UNICAST_RETRY: 10,COUNTER_APS_DATA_TX_UNICAST_FAILED: 5,COUNTER_ROUTE_DISCOVERY_INITIATED: 3,COUNTER_NEIGHBOR_ADDED: 0,COUNTER_NEIGHBOR_REMOVED: 0,COUNTER_NEIGHBOR_STALE: 0,COUNTER_JOIN_INDICATION: 5,COUNTER_CHILD_REMOVED: 0,COUNTER_ASH_OVERFLOW_ERROR: 0,COUNTER_ASH_FRAMING_ERROR: 0,COUNTER_ASH_OVERRUN_ERROR: 0,COUNTER_NWK_FRAME_COUNTER_FAILURE: 0,COUNTER_APS_FRAME_COUNTER_FAILURE: 0,COUNTER_UTILITY: 0,COUNTER_APS_LINK_KEY_NOT_AUTHORIZED: 0,COUNTER_NWK_DECRYPTION_FAILURE: 0,COUNTER_APS_DECRYPTION_FAILURE: 0,COUNTER_ALLOCATE_PACKET_BUFFER_FAILURE: 0,COUNTER_RELAYED_UNICAST: 0,COUNTER_PHY_TO_MAC_QUEUE_LIMIT_REACHED: 0,COUNTER_PACKET_VALIDATE_LIBRARY_DROPPED_COUNT: 0,COUNTER_TYPE_NWK_RETRY_OVERFLOW: 0,COUNTER_PHY_CCA_FAIL_COUNT: 2,COUNTER_BROADCAST_TABLE_FULL: 0,COUNTER_PTA_LO_PRI_REQUESTED: 0,COUNTER_PTA_HI_PRI_REQUESTED: 0,COUNTER_PTA_LO_PRI_DENIED: 0,COUNTER_PTA_HI_PRI_DENIED: 0,COUNTER_PTA_LO_PRI_TX_ABORTED: 0,COUNTER_PTA_HI_PRI_TX_ABORTED: 0
2021-06-11 21:19:03 DEBUG (MainThread) [bellows.ezsp.protocol] Send command readCounters: ()
2021-06-11 21:19:03 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame 241 (readCounters) received: b'0500350009000b0003000000040002000b0006000a0005000300000000000000050000000000000000000000000000000000000000000000000000000000000002000000000000000000000000000000'
2021-06-11 21:19:03 DEBUG (MainThread) [bellows.zigbee.application] EZSP Counters: COUNTER_MAC_RX_BROADCAST: 5,COUNTER_MAC_TX_BROADCAST: 53,COUNTER_MAC_RX_UNICAST: 9,COUNTER_MAC_TX_UNICAST_SUCCESS: 11,COUNTER_MAC_TX_UNICAST_RETRY: 3,COUNTER_MAC_TX_UNICAST_FAILED: 0,COUNTER_APS_DATA_RX_BROADCAST: 4,COUNTER_APS_DATA_TX_BROADCAST: 2,COUNTER_APS_DATA_RX_UNICAST: 11,COUNTER_APS_DATA_TX_UNICAST_SUCCESS: 6,COUNTER_APS_DATA_TX_UNICAST_RETRY: 10,COUNTER_APS_DATA_TX_UNICAST_FAILED: 5,COUNTER_ROUTE_DISCOVERY_INITIATED: 3,COUNTER_NEIGHBOR_ADDED: 0,COUNTER_NEIGHBOR_REMOVED: 0,COUNTER_NEIGHBOR_STALE: 0,COUNTER_JOIN_INDICATION: 5,COUNTER_CHILD_REMOVED: 0,COUNTER_ASH_OVERFLOW_ERROR: 0,COUNTER_ASH_FRAMING_ERROR: 0,COUNTER_ASH_OVERRUN_ERROR: 0,COUNTER_NWK_FRAME_COUNTER_FAILURE: 0,COUNTER_APS_FRAME_COUNTER_FAILURE: 0,COUNTER_UTILITY: 0,COUNTER_APS_LINK_KEY_NOT_AUTHORIZED: 0,COUNTER_NWK_DECRYPTION_FAILURE: 0,COUNTER_APS_DECRYPTION_FAILURE: 0,COUNTER_ALLOCATE_PACKET_BUFFER_FAILURE: 0,COUNTER_RELAYED_UNICAST: 0,COUNTER_PHY_TO_MAC_QUEUE_LIMIT_REACHED: 0,COUNTER_PACKET_VALIDATE_LIBRARY_DROPPED_COUNT: 0,COUNTER_TYPE_NWK_RETRY_OVERFLOW: 0,COUNTER_PHY_CCA_FAIL_COUNT: 2,COUNTER_BROADCAST_TABLE_FULL: 0,COUNTER_PTA_LO_PRI_REQUESTED: 0,COUNTER_PTA_HI_PRI_REQUESTED: 0,COUNTER_PTA_LO_PRI_DENIED: 0,COUNTER_PTA_HI_PRI_DENIED: 0,COUNTER_PTA_LO_PRI_TX_ABORTED: 0,COUNTER_PTA_HI_PRI_TX_ABORTED: 0
2021-06-11 21:19:11 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame 35 (childJoinHandler) received: b'0101786bcc4ad10b006f0d0004'
2021-06-11 21:19:11 DEBUG (MainThread) [bellows.zigbee.application] Received childJoinHandler frame with [1, <Bool.true: 1>, 0x6b78, 00:0d:6f:00:0b:d1:4a:cc, <EmberNodeType.SLEEPY_END_DEVICE: 4>]
2021-06-11 21:19:11 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame 196 (changeSourceRouteHandler) received: b'786b000001'
2021-06-11 21:19:11 DEBUG (MainThread) [bellows.zigbee.application] Received changeSourceRouteHandler frame with [0x6b78, 0x0000, <Bool.true: 1>]
2021-06-11 21:19:11 DEBUG (MainThread) [bellows.ezsp.protocol] Application frame 36 (trustCenterJoinHandler) received: b'786bcc4ad10b006f0d0003000000'
2021-06-11 21:19:11 DEBUG (MainThread) [bellows.zigbee.application] Received trustCenterJoinHandler frame with [0x6b78, 00:0d:6f:00:0b:d1:4a:cc, <EmberDeviceUpdate.STANDARD_SECURITY_UNSECURED_REJOIN: 3>, <EmberJoinDecision.USE_PRECONFIGURED_KEY: 0>, 0x0000]
2021-06-11 21:19:11 INFO (MainThread) [zigpy.application] Device 0x6b78 (00:0d:6f:00:0b:d1:4a:cc) joined the network
2021-06-11 21:19:11 DEBUG (MainThread) [zigpy.application] Skip initialization for existing device 00:0d:6f:00:0b:d1:4a:cc
2021-06-11 21:19:13 DEBUG (MainThread) [bellows.ezsp.protocol] Send command readCounters: ()
