Slider card for shutters' tilt setup
I am trying to put a slider card on Dashboard which will enable me to control tilt of my shutters.
Currently I can set the tilt separately when activating it from the entity. I want a similar sliders on my dashboard.
I am using GitHub - mattieha/slider-button-card: A button card with integrated slider but I cannot get it to change only the tilt.
I set up the card accordingly and in attribute i selected “current_tilt_position”
type: custom:slider-button-card
entity: cover.eg_kuche
slider:
  direction: left-right
  background: solid
  use_state_color: false
  use_percentage_bg_opacity: false
  toggle_on_click: false
  show_track: false
  force_square: false
  invert: true
  show_attribute: false
show_name: true
show_state: true
compact: true
icon:
  show: true
  use_state_color: true
  tap_action:
    action: more-info
  icon: ""
action_button:
  mode: toggle
  icon: mdi:power
  show: false
  show_spinner: true
  tap_action:
    action: toggle
attribute: current_tilt_position
But it still operates the shutters itself and not only the tilt like the entity controls.
I was trying to setup an automation which sets tilt only and it works. I’d say I can connect the slider card to the automation and do it that way but i feel like there is a simpler solution where I setup the card to change the entity tilt, not position.
If I can provide more info, I will do it.
Thanks for help :slight_smile:
