A new behaviour has just started happening. I have a grid card configuration setup for several of my lights. When I slide the switch to turn it on, the physical light turns on, the slider moves to the dimming value but remains grey and shows that it is off. When moving the slider up and down while it is showing off the slider will actually dim the light physically. When I try turning it off with the power switch it will not respond and shut off, as it is already showing that it is off. I have to actually go to the entity itself where the slider switch works and shows the proper state. It seems like the card is broken. I have tried reloading the controlling integrations, I have rebooted the system several times and have reloaded the bridges outside of home assistant. Nothing works. In the screen shot included, you can see the slider switch and it is showing grey and off, however, the light itself is responding to the slider switch value. When clicking on the power button below the slider switch it will not respond. This particular light is a sengled wifi light operating through smartthings. It should be noted that I have other lights from meross that do exactly the same thing and the only thing common is the card itself.
Please provide additional information.
What card type are you using?
How are the lights connected to your system, Zigbee, Wifi, BT, Zwave?
It maybe helpful to share your card code
I have included some additional details
