Hi Everyone,
A few years ago I did this project to automate my backyard window so my dog can go out whenever I’m not home. this was done with ESPHOME and I compiled it to a bin file but unfortunately, I can’t find the YAML file which held all the config. At this opportunity, I wanted to make some enhancements which I realized is super important – currently, my solution doesn’t have a safety mechanism in case my dog is trying to enter or leave the house once the door is CLOSING, one time she almost got caught in the window and ever since I’m a bit traumatized (I always check the security camera before any action, but I don’t think that’s enough).
My goal now is to use a motion sensor that will constantly monitor the door to see if my dog is nearby, if the door is closing and the motion is triggered, I want the window to completely open and wait for a while until it is safe before continue to close the window.
I’m not sure how to start this as my YAML skills are not that great, I’m looking for some guidance on the logic that is required to make this happen (I believe that this can be achieved within the “cover” section?)
this is what I got so far (not tested, just want to know if I’m in the right track first and the logic makes sense):
btw: I tried to mix some information from few sources (the code for the actuator was from DrZZZ which works great, and i tried to add the motion part from kdorff/distance-sensor
##############################---NELLA DOOR OPENER---#######################################
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: !secret ssid
password: !secret ssid_pwd
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
output:
- platform: gpio
pin: D1
- platform: gpio
pin: D2
switch:
- platform: output
output: 'win_1'
- platform: output
output: 'win_2'
cover:
name: "Nella Window Controller"
optimistic: true
open_action:
- switch.turn_off: win2
- switch.turn_on: win1
- delay: 50s
- switch.turn_off: win1
close_action:
- switch.turn_off:
- condition: state
entity_id: sensor.breakbeam_sensor_dist
### maybe we need a while loop? to constantly check if the beam is not broken while closing the window?
state: "off"
- switch.turn_on: win2
- delay: 50s
stop_action:
binary_sensor:
- platform: gpio
pin: D3
name: "Nella Window Control Button"
filters:
invert:
on_press:
then:
- lambda: |
if (id(win_open).state == cover::COVER_OPEN) {
if (id(win1).state){
// window is opening
id(win_open).stop();
} else {
// window is open and not moving
if (id(breakbeam_sensor).state == true)
id(win_open).open();
else
id(win_open).close();
} else {
if (id(win2).state){
// window is closing
} else {
// win is closed and not moving
- name: "PIR Sensor"
platform: vl53l0x
address: 0x29
update_interval: 0.1s
long_range: true
internal: true
# Only send a value back if breakbeam_sensor changes.
filters:
- lambda: !lambda |-
static double minTripDistance = 0.55;
if (x <= minTripDistance) {
if (id(breakbeam_sensor).state == true) {
// Beam was already broken
return {};
// Beam was just broken
id(breakbeam_sensor_top).publish_state(true);
ESP_LOGI("breakbeam_sensor_dist", "Set breakbeam_sensor to Detected");
return {};
else {
if (id(breakbeam_sensor_top).state == false) {
// Beam was already un-broken
return {};
// Beam was just un-broken
id(breakbeam_sensor_top).publish_state(false);
ESP_LOGI("breakbeam_sensor_dist", "Set breakbeam_sensor_top to Cleared");
return {};
