☀️ Slightly improved Weather Forecast Card for Home Assistant
Hey everyone! :wave:
I know, I know… just what the world needs, right? Another weather card. :joy: But I’m actually pretty happy with how this turned out and wanted to share the love.
I recently started reworking my Home Assistant dashboard and got tired of “hacky” fixes for my dashboard trying to visualize weather data. I couldn’t find a custom card that handled long hourly or daily forecasts well, so I decided to try to build one that actually makes visualizing and scrolling through those larger datasets feel smooth. The design tries to adhere to the built-in weather card to some degree.
This started as a learning experiment, so it’s definitely tailored to my personal setup, but I hope others find it useful as well. My time is limited for larger development items but if you have some cool ideas I’m more than happy to hear those!
Some of the key features include
  • Scrollable forecast – View more forecast entries than fit on screen
  • Toggle views – Switch between hourly and daily forecasts with a tap
  • Visualize precipitation – See precipitation amounts for each forecast entry
  • Chart mode – Visualize temperature and precipitation trends
  • Extra attributes – Display extra attributes, like wind direction, wind bearing, or precipitation probability
  • Group hourly data - Aggregate multiple hours of forecast data for easier viewing
  • Custom icons – Use your own weather icons
  • Customizable actions – Configure tap, hold, and double-tap behaviors
  • Sun times - Visualize sunrise and sunset
  • Condition effects - Add a special touch with animated weather effects
  • Card editor - Configure the card directly in the UI. No YAML required
weather-forecast-card-demo
Yes, it has some cool CPU intensive effects too :slight_smile:
weather-forecast-card-effects
Hope you like it! :tada:
Looks nice
looks great - thanks for sharing!
Hey and thanks for the feedback so far!
Few people have been asking for chart line colors. At the moment, the high temp color is your theme’s primary and low temp is the secondary color. Both are configurable via themes.
I did some quick testing and it looks like color steps aren’t too complicated to implement. Before moving forward I would like to ask your opinion if this is sensible or not:
Few changes:
  1. Since we need to distinguish between high and low temp, the low temp is now a dotted line
  2. Use six step color system (colors are configurable via themes)
The goal is to have a smooth transition that feels intuitive across different climates:
  • -10°C / 14°F (Cold): #2196f3 (Deep Blue)
  • 0°C / 32°F (Freezing): #4fb3ff (Cyan/Light Blue)
  • 8°C / 46°F (Chilly): #ffeb3b (Yellow)
  • 18°C / 64°F (Mild): #4caf50 (Green)
  • 26°C / 79°F (Warm): #ff9800 (Orange)
  • 34°C / 93°F (Hot): #f44336 (Red)
Any thoughts?
Love the colors! Two small requests:
Any way we can limit the number of days shown? I’d like it to show 5 or 7 days only rather than the full amount?
Also if there’s way to show the percipitation bar but not the numerical amount under the chart?
I’d love to replace my current weather card!
Came here to request exactly this!
Love this setup, overall. I just have one issue - I have set this card up as part of the title card, and it doesn’t seem to be working in the Android app. I just get the “Configuration error” message with no real details. Any idea what might be going on here? It works fine in Chrome on my desktop, but fails across multiple android devices.
Hey there! Make sure you have restarted the app so that it loads the resources (i.e. your newly installed card). That usually solves the issue.
Hey @bob92
There is a request for limiting the forecast slots. I’m planning on implementing this at some point as few people have requested it.
If you don’t want show the precipitation amount you can set its color to transparent in your theme:
# themes.yaml or whatever file you have
my-theme:
 weather-forecast-card-chart-precipitation-label-color: transparent
This will make it invisible. The reason I’m not yet considering adding this to the card is that most people want to know the actual precipitation amount so this is kind of a rare edge case.
Hope this helps!
That did the trick! Thank you :slight_smile:
Hey everyone!
0.6.0 has now been released. Please find release notes below:
:snowflake: Release highlights
Happy New Year everyone! :tada:
This release focuses on enhancing chart visualization and expanding customization options for the forecast section. In addition to these features, version 0.6.0 includes several fixes based on community-reported issues.
:artist_palette: Color Thresholds and Line Styling
When using the forecast chart mode, you can now bring your data to life with color thresholds.
  • Gradient Styling: Enable forecast.use_color_thresholds to apply predefined color stops to temperature lines, creating a smooth gradient based on the temperature value.
  • Visual Distinction: To make the chart easier to read, the low-temperature line now uses a dashed styling to clearly separate it from the high-temperature line.
  • Updated Defaults: Default line colors have been refreshed to better represent high and low ranges, a common request from the users.
:computer_mouse: Drag-to-Scroll Support
Navigating the horizontal forecast is now much easier for desktop users. This release introduces drag-to-scroll for non-touch pointing devices. You can now grab the forecast container with your mouse and drag or “flick” it to scroll, providing a more intuitive experience outside of mobile devices.
:1234: Configurable Forecast Slots
You now have granular control over how much data is displayed at once. Whether you want a minimal look or a deep dive into the week, you can now limit the number of items shown using:
  • forecast.daily_slots: Limits the number of daily forecast entries.
  • forecast.hourly_slots: Limits the number of hourly forecast entries.
Thanks for the continued feedback and support. I hope you enjoy this release! :sun:
Hi, thanks for this card! I am using it in my living-room on the big wall display - looks great!
Question: Ist it possible to make the font sizes also customizable via css/variables? Espcially in the forecast-chart the fontsize of the temperature values is too small in my usecase.
Hi there! :wave:
Great to hear it fits for your use case!
If you file a feature request to the GitHub project describing the exact needs, i.e. which fonts you would like to customize, I’m more than happy to consider doing it. Doesn’t sound too complicated and I’m sure others would enjoy it as well.
Thanks for the support!
Hi! I’m loving the card - thanks for creating it.
Currently the temperature is displaying up to 1 decimal point. Just to make it tidier, I wonder if you would be able to introduce the option to make it zero decimal places instead please?
Yeah, it would be great if there’s way to make temp values in whole integer without decimal points.
This is a lovely card but I cannot get the blue precipitation bar chart to show.
I do have precipitation_probability in the forecast_hourly_template and forecast_daily_template sections of my template weather entity.
What am I missing?
Hi!
The bar renders the value of the precipitation property in forecast entries. Make sure that is provided by your weather integration:
weather.forecast_home:
  forecast:
    - condition: clear-night
      precipitation_probability: 30 # <- Can be used an forecast.extra_attribute
      precipitation: 0.3 # <- This would render a low bar
      # ... other properties ...
More info on the forecast attributes supported by Home Assistant: Weather - Home Assistant
perfect - thanks!
Great card. Would be nice to allow for custom svg icons for attributes as well :+1:t2:
Hi! :wave:
Support for configuring temperature precisions is coming in the next release:
