The DSMR component has an UART ID option, but as far as I can see the Eastron SDM does not. Is there a way to use one ESP32 (with uart_1 and uart_2 defined) with both devices connected, so I ony have to have 1 device in my utilty closet?
I would point out that you might need a optocoupler between both, because both ports (can) deliver a voltage, also signals to close together might cause noise (cable to close) so you might want to twist cables (pairs) from both sources
the DSMR sends a message very x seconds (1 min tot 5 min) I guess the eastron sends more messages / pulses … but both should be well within the limits
aka “gaat wel” with the correct esp (that has 2 tx/rx available)
from Modbus Controller — ESPHome (example)
actually you do somehting like (sorry no for yaml format) AA ,BB,CC,DD are the GPIO pins that go with either UART 1 or 2
I know how to setup the uart component. The question is not how to setup the uarts, but how to bind the right uart_id to the SDM-meter component, which does not have the uart_id variable.
the reaction from my previous post combines with your reply above it
that should work, and yes its a guess indeed the documentation is not very clear although this sounds logical the only way is to try it in real life unfortunatly
My Eastron meter will be installed next week (together with a Zappi carcharger). So Although I am prepairing the ESP this weekend we have to wait till then to see if it works.
