What configuration do you have for SlimmeLezer+ in esphome for Sweden, Vattenfall.
I have this, but can’t get out what it would export.
Should there be a connection to the NordPol spot price, right?
What do you have as a configuration file.
Grateful for answers.
comment: "El"
platform: ESP8266
esp8266_restore_from_flash: true
board: d1_mini
name_add_mac_suffix: false
# Enable logging
# Enable Home Assistant API
api:
ota:
password: "63aed3fe496c96d8f19550e082dbfd9" 7
dashboard_import:
package_import_url: github://zuidwijk/dsmr/slimmelezer.yaml
wifi:
ssid: !secret wifi_ssid
use_address: 192.168.1.31
manual_ip:
static_ip: 192.168.1.31
gateway: 192.168.1.1
subnet: 255.255.255.0
dns1: 192.168.1.1
domain: .home
ap:
ssid: "Vattenfall5 Fallback Hotspot"
password: "DvfScJ6pnyh"
captive_portal:
# Enable logging
logger:
baud_rate: 0
web_server:
port: 80
uart:
baud_rate: 115200
rx_pin: D7
rx_buffer_size: 1700
debug:
direction: BOTH
dummy_receiver: false
after:
delimiter: "\n"
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
dsmr:
max_telegram_length: 1700
- platform: dsmr
energy_delivered_tariff1:
name: "Energy Consumed Tariff 1"
energy_delivered_tariff2:
name: "Energy Consumed Tariff 2"
energy_returned_tariff1:
name: "Energy Produced Tariff 1"
energy_returned_tariff2:
name: "Energy Produced Tariff 2"
power_delivered:
name: "Power Consumed"
accuracy_decimals: 3
power_returned:
name: "Power Produced"
electricity_failures:
name: "Electricity Failures"
icon: mdi:alert
electricity_long_failures:
name: "Long Electricity Failures"
icon: mdi:alert
voltage_l1:
name: "Voltage Phase 1"
voltage_l2:
name: "Voltage Phase 2"
voltage_l3:
name: "Voltage Phase 3"
current_l1:
name: "Current Phase 1"
current_l2:
name: "Current Phase 2"
current_l3:
name: "Current Phase 3"
power_delivered_l1:
name: "Power Consumed Phase 1"
power_delivered_l2:
name: "Power Consumed Phase 2"
power_delivered_l3:
name: "Power Consumed Phase 3"
power_returned_l1:
name: "Power Produced Phase 1"
power_returned_l2:
name: "Power Produced Phase 2"
power_returned_l3:
name: "Power Produced Phase 3"
gas_delivered:
name: "Gas Consumed"
- platform: uptime
- platform: wifi_signal
name: "vattenfall5 Wi-Fi Signal"
update_interval: 60s
text_sensor:
- platform: dsmr
identification:
name: "DSMR Identification"
p1_version:
- platform: wifi_info
ip_address:
name: "SlimmeLezer IP Address"
ssid:
name: "SlimmeLezer Wi-Fi SSIDesphome:
comment: "El"
platform: ESP8266
board: d1_mini
# Enable logging
api:
ota:
dashboard_import:
wifi:
manual_ip:
dns1: 192.168.1.1
domain: .home
ap:
password: "DvfScJ6pnyPh"
captive_portal:
# Enable logging
logger:
baud_rate: 0
web_server:
port: 80
uart:
baud_rate: 115200
rx_pin: D7
debug:
direction: BOTH
after:
delimiter: "\n"
sequence:
dsmr:
- platform: dsmr
power_delivered:
power_returned:
icon: mdi:alert
icon: mdi:alert
voltage_l1:
voltage_l2:
voltage_l3:
current_l1:
current_l2:
current_l3:
power_delivered_l1:
power_delivered_l2:
power_delivered_l3:
power_returned_l1:
power_returned_l2:
power_returned_l3:
gas_delivered:
- platform: uptime
text_sensor:
- platform: dsmr
identification:
p1_version:
ip_address:
ssid:
name: "SlimmeLezer Wi-Fi SSID"
bssid:
name: "SlimmeLezer Wi-Fi BSSID"
- platform: version
hide_timestamp: false
bssid:
- platform: version
