SlimmeLezer YAML for Austrian Smartmeters
I’m gonna try to get the YAML for ESPHome compiled to work with two Encryption Keys. As it is the first time in my life where i touch a YAML file, if some experienced of you can check the code and help me to avoid the Error message.
Error:
INFO Reading configuration /config/esphome/slimmelezer.yaml...
Failed config
dsmr: [source /config/esphome/slimmelezer.yaml:84]
  - id: dsmr_instance
    [auth_key] is an invalid option for [0]. Please check the indentation.
    auth_key: BC63E6ABE5AC731ABDE2190E419XXXXX
    [unicast_key] is an invalid option for [0]. Please check the indentation.
    unicast_key: 5A7B2641E7C4031A43FD0F0BBA1XXXXX
This is the current YAML:
substitutions:
  device_name: slimmelezer
  device_description: "Austria Smartmeter P1 module to read your smart meter"
esphome:
  comment: "${device_description}"
  platform: ESP8266
  esp8266_restore_from_flash: true
  board: d1_mini
  name_add_mac_suffix: false
  project:
    version: "1.0"
  on_boot:
    then:
      - if:
          condition:
            lambda: return id(has_key);
          then:
            - lambda: |-
                std::string auth_key(id(""stored_decryption_auth_key""), 32);
                std::string unicast_key(id(stored_decryption_unicast_key), 32);
                id(dsmr_instance).set_decryption_key(auth_key, unicast_key);
          else:
            - logger.log:
                level: info
                format: "Not using decryption key. If you need to set a key use Home Assistant service 'ESPHome:  ${device_name}_set_dsmr_key'"
wifi:
  networks:
    - ssid: "SSID here"
      password: "PW here"
  ap:
    ssid: ${device_name}
    ap_timeout: 15s
captive_portal:
# Enable logging
logger:
  baud_rate: 0
# Enable Home Assistant API
api:
  services:
    service: set_dsmr_key
    variables:
      private_key: string
    then:
      - logger.log:
          format: Setting private key %s. Set to empty string to disable
          args: [private_key.c_str()]
      - globals.set:
          value: lambda "return private_key.length() == 32;"
      - lambda: |-
          if (private_key.length() == 32)
            private_key.copy(id(stored_decryption_key), 32);
          id(dsmr_instance).set_decryption_key(private_key);
ota:
web_server:
  port: 80
uart:
  baud_rate: 115200
  rx_pin: D7
globals:
  - id: has_key
    type: bool
    restore_value: yes
    initial_value: "false"
  - id: stored_decryption_key
    type: char[32]
    restore_value: yes
dsmr:
  - id: dsmr_instance
  - platform: dsmr
    energy_delivered_lux:
      name: "Energy Consumed Austria"
      state_class: total_increasing
    energy_delivered_tariff1:
      name: "Energy Consumed Tariff 1"
    energy_delivered_tariff2:
      name: "Energy Consumed Tariff 2"
    energy_returned_lux:
      name: "Energy Produced Austria"
    energy_returned_tariff1:
      name: "Energy Produced Tariff 1"
    energy_returned_tariff2:
      name: "Energy Produced Tariff 2"
    power_delivered:
      name: "Power Consumed"
      accuracy_decimals: 3
    power_returned:
      name: "Power Produced"
    electricity_failures:
      name: "Electricity Failures"
      icon: mdi:alert
    electricity_long_failures:
      name: "Long Electricity Failures"
      icon: mdi:alert
    voltage_l1:
      name: "Voltage Phase 1"
    voltage_l2:
      name: "Voltage Phase 2"
    voltage_l3:
      name: "Voltage Phase 3"
    current_l1:
      name: "Current Phase 1"
    current_l2:
      name: "Current Phase 2"
    current_l3:
      name: "Current Phase 3"
    power_delivered_l1:
      name: "Power Consumed Phase 1"
    power_delivered_l2:
      name: "Power Consumed Phase 2"
    power_delivered_l3:
      name: "Power Consumed Phase 3"
    power_returned_l1:
      name: "Power Produced Phase 1"
    power_returned_l2:
      name: "Power Produced Phase 2"
    power_returned_l3:
      name: "Power Produced Phase 3"
    gas_delivered:
      name: "Gas Consumed"
    gas_delivered_be:
      name: "Gas Consumed Austria"
  - platform: uptime
  - platform: wifi_signal
    name: "SlimmeLezer Wi-Fi Signal"
    update_interval: 60s
text_sensor:
  - platform: dsmr
    identification:
      name: "DSMR Identification"
    p1_version:
    p1_version_be:
      name: "DSMR Version Austria"
  - platform: wifi_info
    ip_address:
      name: "SlimmeLezer IP Address"
    ssid:
      name: "SlimmeLezer Wi-Fi SSID"
    bssid:
      name: "SlimmeLezer Wi-Fi BSSID"
  - platform: version
    hide_timestamp: true
Any help would be great! I’ve no more idea what to change.
Hello, is there any news? Have you been able to solve the authentication? I also have a Slimmelezer at E-Netze.
Hi Bernhard,
do you found a solution? I need also a working yaml for Slimme - in my case Netz NÖ and a Kaifa Smartmeter.
Danke
Erich
