Slimmelezer.yaml not working
Yesterday I got my SlimmeLezer in the mail and today I tried installing it. Since it came with no instructions I thought I had to create a configuration using the ESPHome addon using this: slimmelezer.yaml.
Edited the file to contain the WiFi SSID and key and tried installing it.
That did sort of work, it flashed fine but it did not connect to WiFi. Status of it is offline.
So, I am doing something wrong. Probably something simple. Can somebody help me?
How did you flash it?
Using the ESPHome addon in home assistant
I meant with which device. Via the browser https direct method or is it connected via an UART to the HA itself? and what did the log say?
Did you disconnect it from the UART before resetting it? Sometimes it will not boot when still connected.
Also: GitHub - zuidwijk/dsmr
Via the browser with the device connected via a USB cable to the RPi4.
I will try replugging the device
Unfortunately that did not solve my issue. No new device in my wireless network :frowning:
What does the log say after the upload?
Just load in the code from ESPHome.
Also do you have a secret file or did you remove the !secret from the code you pasted
This is the yaml I am installing
substitutions:
  device_name: slimmelezer
  device_description: "DIY P1 module to read your smart meter"
esphome:
  comment: "${device_description}"
  platform: ESP8266
  esp8266_restore_from_flash: true
  board: d1_mini
  name_add_mac_suffix: true
  project:
    version: "1.0"
  on_boot:
    then:
      - if:
            lambda: return id(has_key);
          then:
            - lambda: |-
                std::string key(id(stored_decryption_key), 32);
                id(dsmr_instance).set_decryption_key(key);
          else:
            - logger.log:
                level: info
                format: "Not using decryption key. If you need to set a key use Home Assistant service 'ESPHome:  ${device_name}_set_dsmr_key'"
wifi:
  networks:
    - ssid: "SSID"
      password: "WirelessKey"
  ap:
    ssid: ${device_name}
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  services:
    service: set_dsmr_key
    variables:
      private_key: string
    then:
      - logger.log:
          format: Setting private key %s. Set to empty string to disable
          args: [private_key.c_str()]
      - globals.set:
          value: !lambda "return private_key.length() == 32;"
      - lambda: |-
          if (private_key.length() == 32)
            private_key.copy(id(stored_decryption_key), 32);
          id(dsmr_instance).set_decryption_key(private_key);
ota:
web_server:
  port: 80
uart:
  baud_rate: 115200
  rx_pin: D7
globals:
  - id: has_key
    type: bool
    restore_value: yes
    initial_value: "false"
  - id: stored_decryption_key
    type: char[32]
    restore_value: yes
dsmr:
  # For Luxembourg users set here your decryption key
  #decryption_key: !secret decryption_key // enable this when using decryption for Luxembourg; key like '00112233445566778899AABBCCDDEEFF'
  - platform: dsmr
    energy_delivered_lux:
      name: "Energy Consumed Luxembourg"
    energy_delivered_tariff1:
      name: "Energy Consumed Tariff 1"
    energy_delivered_tariff2:
      name: "Energy Consumed Tariff 2"
    energy_returned_lux:
      name: "Energy Produced Luxembourg"
    energy_returned_tariff1:
      name: "Energy Produced Tariff 1"
    energy_returned_tariff2:
      name: "Energy Produced Tariff 2"
    power_delivered:
      name: "Power Consumed"
      accuracy_decimals: 0
      filters:
        - multiply: 1000
    power_returned:
      name: "Power Produced"
      filters:
        - multiply: 1000
    electricity_failures:
      name: "Electricity Failures"
      icon: mdi:alert
    electricity_long_failures:
      name: "Long Electricity Failures"
      icon: mdi:alert
    voltage_l1:
      name: "Voltage Phase 1"
    voltage_l2:
      name: "Voltage Phase 2"
    voltage_l3:
      name: "Voltage Phase 3"
    current_l1:
      name: "Current Phase 1"
    current_l2:
      name: "Current Phase 2"
    current_l3:
      name: "Current Phase 3"
    power_delivered_l1:
      name: "Power Consumed Phase 1"
      filters:
        - multiply: 1000
    power_delivered_l2:
      name: "Power Consumed Phase 2"
      filters:
        - multiply: 1000
    power_delivered_l3:
      name: "Power Consumed Phase 3"
      filters:
        - multiply: 1000
    power_returned_l1:
      name: "Power Produced Phase 1"
      filters:
        - multiply: 1000
    power_returned_l2:
      name: "Power Produced Phase 2"
      filters:
        - multiply: 1000
    power_returned_l3:
      name: "Power Produced Phase 3"
      filters:
        - multiply: 1000
    gas_delivered:
      name: "Gas Consumed"
    gas_delivered_be:
      name: "Gas Consumed Belgium"
  - platform: uptime
  - platform: wifi_signal
    update_interval: 60s
text_sensor:
  - platform: dsmr
    identification:
      name: "DSMR Identification"
    p1_version:
    p1_version_be:
      name: "DSMR Version Belgium"
  - platform: wifi_info
    ip_address:
    ssid:
    bssid:
It outputs this:
INFO Reading configuration /config/esphome/slimme-lezer.yaml...
INFO Generating C++ source...
INFO Compiling app...
INFO Running:  platformio run -d /config/esphome/slimmelezer
Processing slimmelezer (board: d1_mini; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
PACKAGES:
 - framework-arduinoespressif8266 3.20704.0 (2.7.4)
 - tool-esptool 1.413.0 (4.13)
 - tool-esptoolpy 1.20800.0 (2.8.0)
 - toolchain-xtensa 2.40802.200502 (4.8.2)
Library Manager: Installing Update
Library Manager: Already installed, built-in library
Dependency Graph
|-- <ESPAsyncTCP-esphome> 1.2.3
|   |-- <ESP8266WiFi> 1.0
|-- <ESPAsyncWebServer-esphome> 1.3.0
|   |-- <Hash> 1.0
|   |-- <Crypto> 0.2.0
|   |-- <ArduinoJson-esphomelib> 5.13.3
|-- <ESP8266mDNS> 1.2
|-- <Dsmr> 0.3.0
|-- <Crypto> 0.2.0
|-- <DNSServer> 1.1.1
Retrieving maximum program size /data/slimmelezer/.pioenvs/slimmelezer/firmware.elf
Checking size /data/slimmelezer/.pioenvs/slimmelezer/firmware.elf
RAM:   [====      ]  43.0% (used 35220 bytes from 81920 bytes)
Flash: [====      ]  43.6% (used 455188 bytes from 1044464 bytes)
========================= [SUCCESS] Took 9.72 seconds =========================
INFO Successfully compiled program.
INFO Running:  esptool.py --before default_reset --after hard_reset --baud 460800 --chip esp8266 --port /dev/ttyUSB1 write_flash 0x0 /data/slimmelezer/.pioenvs/slimmelezer/firmware.bin
esptool.py v3.1
Serial port /dev/ttyUSB1
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 3c:61:05:d1:99:6a
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00070fff...
Compressed 459344 bytes to 313425...
Wrote 459344 bytes (313425 compressed) at 0x00000000 in 7.4 seconds (effective 494.0 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
INFO Successfully uploaded program.
INFO Starting log output from /dev/ttyUSB1 with baud rate 115200
[20:07:16]\033Ğ\xc4\x90\xec\x92\xc7r\xdc;\x88\xfc\x82n\xc4b\xe0[I][logger:170]: Log initialized
Well, lets first of all check if it connects: (Only use this code, not the rest)
substitutions:
esphome:
  platform: ESP8266
  board: d1_mini
ota:
  password: "your ota password"
logger:
wifi:
  ssid: "wifissid"
  password: "password"
  fast_connect: true
Fill in the ota, ssid and pw so you can see if it connects.
ota only needed if you want to use wifi upload for next tests.
Looking at the code.
wifi:
  networks:
    - ssid: "SSID"
Stands out as a format never saw in my codes. But could be old code.
Also look at the ESPHome link, the code for reading out is updated as its integrated in ESPHome now.
Are you located in Luxembourg?
I am located in the Netherlands so the whole part about the decryption key can be dropped.
According to this the wifi syntax seems fine.
Now it connects :partying_face:
esptool.py v3.1
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
Changed.
Flash will be erased from 0x00000000 to 0x00051fff...
Compressed 335024 bytes to 239973...
Wrote 335024 bytes (239973 compressed) at 0x00000000 in 5.7 seconds (effective 466.7 kbit/s)...
Leaving...
[20:49:16]\033Ğ\x84\x90\xec\x92\xc7r\xdc;\x88\xfc\x82n\xc4b\xe0[I][logger:170]: Log initialized
[20:49:16][C][ota:378]: There have been 0 suspected unsuccessful boot attempts.
[20:49:16][I][app:029]: Running through setup()...
[20:49:16][C][wifi:037]: Setting up WiFi...
[20:49:16][I][wifi:250]: WiFi Connecting to [redacted]...
[20:49:20][I][wifi:513]: WiFi Connected!
[20:49:20][C][wifi:359]:   SSID: [redacted]
[20:49:20][C][wifi:360]:   IP Address: 192.168.0.102
[20:49:20][C][wifi:362]:   BSSID: [redacted]
[20:49:20][C][wifi:363]:   Hostname: 'slimmelezer'
[20:49:20][C][wifi:367]:   Signal strength: -36 dB ▂▄▆█
[20:49:20][C][wifi:371]:   Channel: 1
[20:49:20][C][wifi:372]:   Subnet: 255.255.255.0
[20:49:20][C][wifi:373]:   Gateway: 192.168.0.1
[20:49:20][C][wifi:374]:   DNS1: 192.168.0.1
[20:49:20][C][wifi:375]:   DNS2: (IP unset)
[20:49:20][C][ota:029]: Over-The-Air Updates:
[20:49:20][C][ota:030]:   Address: 192.168.0.150:8266
[20:49:20][C][ota:032]:   Using Password.
[20:49:20][I][app:060]: setup() finished successfully!
[20:49:20][I][app:106]: ESPHome version 2021.8.2 compiled on Aug 29 2021, 20:48:20
[20:49:20][C][wifi:499]: WiFi:
[20:49:20][C][wifi:367]:   Signal strength: -35 dB ▂▄▆█
[20:49:20][C][logger:189]: Logger:
[20:49:20][C][logger:190]:   Level: DEBUG
[20:49:20][C][logger:191]:   Log Baud Rate: 115200
[20:49:20][C][logger:192]:   Hardware UART: UART0
So my guess is that it is a typo somewhere. Going to try adding in a few extra lines at a time.
I do not have a secret file
This is my current yaml. The weird thing is, EPSHome dashboard does not see it but I can connect to the static ip address :confused:
substitutions:
  device_name: "slimmelezer"
esphome:
  platform: ESP8266
  board: d1_mini
  project:
    version: "1.0"
#  on_boot:
#    then:
#      - if:
#          condition:
#            lambda: return id(has_key);
#          then:
#            - lambda: |-
#                std::string key(id(stored_decryption_key), 32);
#                id(dsmr_instance).set_decryption_key(key);
#          else:
#            - logger.log:
#                level: info
#                format: "Not using decryption key. If you need to set a key use Home Assistant service 'ESPHome:  ${device_name}_set_dsmr_key'"
wifi:
  ssid: [redacted]
  password: [redacted]
  fast_connect: true
  manual_ip:
    static_ip: 192.168.0.150
    gateway: 192.168.0.1
    subnet: 255.255.255.0
    dns1: 192.168.0.1
  ap:
captive_portal:
# Enable logging
logger:
#api:
#  services:
#    service: set_dsmr_key
#    variables:
#      private_key: string
#    then:
#      - logger.log:
#          format: Setting private key %s. Set to empty string to disable
#          args: [private_key.c_str()]
#      - globals.set:
#          id: has_key
#          value: !lambda "return private_key.length() == 32;"
#      - lambda: |-
#          if (private_key.length() == 32)
#            private_key.copy(id(stored_decryption_key), 32);
#          id(dsmr_instance).set_decryption_key(private_key);
ota:
web_server:
  port: 80
#uart:
#  baud_rate: 115200
#  rx_pin: D7
globals:
  - id: has_key
    type: bool
    restore_value: yes
    type: char[32]
    restore_value: yes
#dsmr:
#  id: dsmr_instance
#  - platform: dsmr
#    energy_delivered_lux:
#      name: "Energy Consumed Luxembourg"
#    energy_delivered_tariff1:
#      name: "Energy Consumed Tariff 1"
#    energy_delivered_tariff2:
#      name: "Energy Consumed Tariff 2"
#    energy_returned_lux:
#      name: "Energy Produced Luxembourg"
#    energy_returned_tariff1:
#      name: "Energy Produced Tariff 1"
#    energy_returned_tariff2:
#      name: "Energy Produced Tariff 2"
#    power_delivered:
#      name: "Power Consumed"
#      accuracy_decimals: 0
#      filters:
#        - multiply: 1000
#    power_returned:
#      name: "Power Produced"
#      filters:
#        - multiply: 1000
#    electricity_failures:
#      name: "Electricity Failures"
#      icon: mdi:alert
#    electricity_long_failures:
#      name: "Long Electricity Failures"
#      icon: mdi:alert
#    voltage_l1:
#      name: "Voltage Phase 1"
#    voltage_l2:
#      name: "Voltage Phase 2"
#    voltage_l3:
#      name: "Voltage Phase 3"
#    current_l1:
#      name: "Current Phase 1"
#    current_l2:
#      name: "Current Phase 2"
#    current_l3:
#      name: "Current Phase 3"
#    power_delivered_l1:
#      name: "Power Consumed Phase 1"
#      filters:
#        - multiply: 1000
#    power_delivered_l2:
#      name: "Power Consumed Phase 2"
#      filters:
#        - multiply: 1000
#    power_delivered_l3:
#      name: "Power Consumed Phase 3"
#      filters:
#        - multiply: 1000
#    power_returned_l1:
#      name: "Power Produced Phase 1"
#      filters:
#        - multiply: 1000
#    power_returned_l2:
#      name: "Power Produced Phase 2"
#      filters:
#        - multiply: 1000
#    power_returned_l3:
#      name: "Power Produced Phase 3"
#      filters:
#        - multiply: 1000
#    gas_delivered:
#      name: "Gas Consumed"
#    gas_delivered_be:
#      name: "Gas Consumed Belgium"
#  - platform: uptime
#    name: "Uptime"
#  - platform: wifi_signal
#    name: "Wi-Fi Signal"
#    update_interval: 60s
text_sensor:
#  - platform: dsmr
#    identification:
#      name: "DSMR Identification"
#    p1_version:
#      name: "DSMR Version"
#    p1_version_be:
#      name: "DSMR Version Belgium"
    ip_address:
    ssid:
    bssid:
Enabling anything else and the yaml is not valid or if it is, the device seems to hang on boot.
Of course it wont show up in HA as you have not enabled the api.
And you are still not using the code from the ESPHome but the original code you linked.
So a couple of things:
  • api is not set, so in integration it will not show up.
  • You will need to figure out what info you want to have and make the yaml file according to that.
  • Trim that code a bit. Still alot of stuff in there that is pointless. Like the wifi_info.
First part of the code:
esphome:
  platform: ESP8266
  board: d1_mini
# Enable logging
logger:
api:
ota:
wifi:
  ssid: "ssid"
  fast_connect: true
  ap:
    ssid: "slimmelezer"
    password: "g6ThtO24Kc4M"
captive_portal:
This will set the name and rest of the basic info to boot and be reachable, and connect to HA
For the rest of the code you will need to add the sensors and whatever else you want.
  - platform: dsmr
      name: Verbruik Tarief Laag
      name: Verbruik Tarief Hoog
Adjust and add whatever sensors you want in to show up in HA
Hey did you get this working with the slimmelezer.yaml template from GitHub? I think I’m having the same issue over here: How to set up Slimmelezer with Home Assistant for dummies
When I use this slimmelezer.yaml:
substitutions:
esphome:
  platform: ESP8266
  board: d1_mini
# Enable logging
logger:
api:
ota:
  password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  fast_connect: true
  ap:
    password: !secret ap_password
captive_portal:
web_server:
  port: 80
uart:
  baud_rate: 115200
  rx_pin: D7
dsmr:
Then the logging always hangs at this point. I’ve tried pairing down the yaml a lot to narrow down the root cause but no luck so far. Will try to go further later.
INFO Reading configuration /config/esphome/slimmelezer.yaml...
PACKAGES:
Dependency Graph
|   |-- <Hash> 1.0
|   |-- <Crypto> 0.2.0
|-- <Dsmr> 0.3.0
|-- <Crypto> 0.2.0
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/api/api_connection.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/api/api_pb2_service.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/api/api_server.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/api/list_entities.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/api/proto.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/api/subscribe_state.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/api/user_services.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/api/util.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/dsmr/dsmr.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/logger/logger.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/ota/ota_component.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/sensor/automation.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/uart/uart.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/uart/uart_esp32.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/uart/uart_esp8266.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/web_server/web_server.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/wifi/wifi_component.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/wifi/wifi_component_esp32.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/core/application.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/core/application_esp32.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/core/application_esp8266.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/core/component.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/core/controller.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/core/esphal.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/core/log.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/core/preferences.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/esphome/core/util.cpp.o
Compiling /data/slimmelezer/.pioenvs/slimmelezer/src/main.cpp.o
Linking /data/slimmelezer/.pioenvs/slimmelezer/firmware.elf
Building /data/slimmelezer/.pioenvs/slimmelezer/firmware.bin
RAM:   [====      ]  40.7% (used 33320 bytes from 81920 bytes)
Flash: [====      ]  40.5% (used 422508 bytes from 1044464 bytes)
Creating BIN file "/data/slimmelezer/.pioenvs/slimmelezer/firmware.bin" using "/root/.platformio/packages/framework-arduinoespressif8266/bootloaders/eboot/eboot.elf" and "/data/slimmelezer/.pioenvs/slimmelezer/firmware.elf"
========================= [SUCCESS] Took 40.76 seconds =========================
esptool.py v3.1
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: bc:ff:4d:1a:34:10
Uploading stub...
Running stub...
Stub running...
Changed.
Flash will be erased from 0x00000000 to 0x00068fff...
Compressed 426656 bytes to 296420...
Wrote 426656 bytes (296420 compressed) at 0x00000000 in 7.3 seconds (effective 470.0 kbit/s)...
Leaving...
[08:51:57]bl`\x9cb\x8el\x92lr\x92`\xfc\x82nb\xe0[I][logger:170]: Log initialized
Update: Not sure why, but I got it working with this yaml:
substitutions:
esphome:
  platform: ESP8266
  board: d1_mini
  #esp8266_restore_from_flash: true
  #name_add_mac_suffix: true
  #project:
  #  name: zuidwijk.slimmelezer
  #  version: "1.0"
  #on_boot:
  #  then:
  #    - if:
  #        condition:
  #        then:
  #          - lambda: |-
  #        else:
  #          - logger.log:
  #              level: info
wifi:
  fast_connect: true
  ap:
captive_portal:
# Enable logging
logger:
api:
  #services:
  #  variables:
  #  then:
  #    - logger.log:
  #    - globals.set:
  #        id: has_key
  #    - lambda: |-
ota:
web_server:
  port: 80
uart:
  baud_rate: 115200
  rx_pin: D7
#globals:
#  - id: has_key
#    type: bool
#    restore_value: yes
#    initial_value: "false"
#  - id: stored_decryption_key
#    type: char[32]
dsmr:
# selection of sensors from
# https://github.com/zuidwijk/dsmr/blob/2a60634ab628626951736d404878e1361c23868b/slimmelezer.yaml
  - platform: dsmr
    #energy_delivered_lux:
    #energy_returned_lux:
    power_delivered:
      filters:
        - multiply: 1000
    power_returned:
      filters:
        - multiply: 1000
      icon: mdi:alert
      icon: mdi:alert
    voltage_l1:
    voltage_l2:
    voltage_l3:
    current_l1:
    current_l2:
    current_l3:
    power_delivered_l1:
      filters:
        - multiply: 1000
    power_delivered_l2:
      filters:
        - multiply: 1000
    power_delivered_l3:
      filters:
        - multiply: 1000
    power_returned_l1:
      filters:
        - multiply: 1000
    power_returned_l2:
      filters:
        - multiply: 1000
    power_returned_l3:
      filters:
        - multiply: 1000
    gas_delivered:
    #gas_delivered_be:
  - platform: uptime
text_sensor:
  - platform: dsmr
    identification:
    p1_version:
    #p1_version_be:
    ip_address:
    ssid:
    bssid:
You are absolutely right. Stubborn first timer here :sweat_smile:
I think we both like to mess around with things. This information is also in your thread, but upload the default yaml, connect it to your smart power meter, log into it using your phone, enter wifi credentials and simply wait for it to show up in home assistant. No need to mess around with yaml’s.
This will not work for me, without the dsmr: declaration.
That will not work without the uart: entry.
That gives me an error on the D7 pin.
I’m lost atm :frowning:
Update: I was connecting it to the HA server itself and installing it from the ESPhome dashboard which is not the way to go. Flashed the firmware from the zuidwijk productpage with esphome-flasher and things look better. I’m getting readings in the sensor entities, but the energy dashboard itself is reporting ‘Unexpected state class’.
There were some changes in HA 2021.9 for the state_class of energy sensors. That got also changed with the latest firmware of slimmelezer (I think 2 days ago).
The firmware in my slimmelezer worked with HA 2021.8, but gave a similar error about state_class after updating HA to 2021.9. This was solved by updating slimmelezer firmware (I used the yaml from Github, but OTA file from product page should also work).
Hi all, how can i implemetn this yaml to the esp slimmelezer without setting up homeassistant? Belgian ESPHome config for Slimmelezer(+) by Marcel Zuidwijk :: Sequr
I’ve moved houses and need to move and setup my server…
