Slope Control of lights (in Modbus, MQTT etc.)
I have noticed that the edge control option is missing in HA.
You often have impulse relays or devices that have integrated logic themselves. Here it is then necessary that a function, for example light_on, can be triggered with a pulse.
I would suggest a YAML integration in the following way (using Modbus as an example):
    lights:
      - name: "light"
        unique_id: "light"
        address: 1
        write_type: coil
        command_on_slope: 1s
        command_off_slope: 1s
        verify:
            input_type: coil
            address: 8192
            state_on: 1
            state_off: 0
This is currently only possible in a very complicated way via automation.
Another cool option would be that the output is only set when the UI button is pressed. The actual value is then returned via verify.
I hope my Request get implemented.
Greeting
Dominik
Greetings
Dominik
