Hello - I just recently added a new device, MP21ZP, and have noticed intermittent slowdowns with my z-wave devices. From looking at the ZWave To MQTT logs it seems as if though MQTT client closes, refuses connection, and reconnects. I have a theory that this could be caused by the large number messages being caused by new MP21ZP as it reports amps/watts every few ms but at the same time I would think this shouldn’t cause any issues?
I’m running both ZWaveToMQTT and Home Assistant in containers on my Raspberry PI 4 and using a “Zooz 700 Series Z-Wave Plus S2 USB Stick ZST10 700”
logs:
2021-11-01 12:55:22.535 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 133.8 => 133.8
2021-11-01 12:55:22.616 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771322616, value: 133.8 } with options { qos: 1, retain: true }
2021-11-01 12:55:22.617 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 133.8 => 133.8
2021-11-01 12:55:22.639 INFO MQTT: MQTT client reconnecting
2021-11-01 12:55:22.643 INFO MQTT: connect ECONNREFUSED 127.0.0.1:1883
2021-11-01 12:55:22.650 INFO MQTT: MQTT client closed
2021-11-01 12:55:22.697 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771322697, value: 133.8 } with options { qos: 1, retain: true }
2021-11-01 12:55:22.698 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 133.8 => 133.8
2021-11-01 12:55:22.796 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771322796, value: 133.8 } with options { qos: 1, retain: true }
2021-11-01 12:55:22.796 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 133.8 => 133.8
2021-11-01 12:55:22.822 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771322821, value: 133.8 } with options { qos: 1, retain: true }
2021-11-01 12:55:22.822 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 133.8 => 133.8
2021-11-01 12:55:22.867 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771322866, value: 133.8 } with options { qos: 1, retain: true }
2021-11-01 12:55:22.868 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 133.8 => 133.8
2021-11-01 12:55:23.026 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771323026, value: 133.8 } with options { qos: 1, retain: true }
2021-11-01 12:55:23.027 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 133.8 => 133.8
2021-11-01 12:55:23.092 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771323092, value: 133.8 } with options { qos: 1, retain: true }
2021-11-01 12:55:23.093 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 133.8 => 133.8
2021-11-01 12:55:23.174 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771323174, value: 133.8 } with options { qos: 1, retain: true }
2021-11-01 12:55:23.175 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 133.8 => 133.8
2021-11-01 12:55:23.343 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771323343, value: 133.8 } with options { qos: 1, retain: true }
2021-11-01 12:55:23.347 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 133.8 => 133.8
2021-11-01 12:55:23.396 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771323396, value: 133.8 } with options { qos: 1, retain: true }
2021-11-01 12:55:23.397 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 133.8 => 133.8
2021-11-01 12:55:23.427 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771323427, value: 133.8 } with options { qos: 1, retain: true }
2021-11-01 12:55:23.428 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 133.8 => 133.8
2021-11-01 12:55:23.579 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771323579, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:23.580 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.22 => 1.3
2021-11-01 12:55:23.626 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771323626, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:23.627 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:23.656 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771323656, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:23.657 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:23.750 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771323749, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:23.750 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:23.797 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771323797, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:23.798 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:23.879 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771323879, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:23.880 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:23.976 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771323976, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:23.977 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:24.019 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771324019, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:24.020 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:24.079 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771324079, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:24.080 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:24.169 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771324169, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:24.170 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:24.233 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771324232, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:24.234 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:24.280 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771324279, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:24.280 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:24.353 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771324353, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:24.354 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:24.414 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771324414, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:24.415 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:24.439 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771324439, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:24.439 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:24.528 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771324528, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:24.529 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:24.576 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771324576, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:24.577 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:24.623 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771324623, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:24.624 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:24.721 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771324720, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:24.722 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:24.748 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771324747, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:24.748 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:24.776 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771324775, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:24.776 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:24.859 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771324859, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:24.860 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:24.905 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771324905, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:24.907 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:25.058 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771325058, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:25.059 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:25.115 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771325115, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:25.116 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:25.199 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771325198, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:25.199 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:25.369 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771325369, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:25.370 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:25.434 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771325434, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:25.435 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:25.464 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771325464, value: 1.3 } with options { qos: 1, retain: true }
2021-11-01 12:55:25.465 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.3
2021-11-01 12:55:25.650 INFO MQTT: MQTT client reconnecting
2021-11-01 12:55:25.654 INFO MQTT: connect ECONNREFUSED 127.0.0.1:1883
2021-11-01 12:55:25.664 INFO MQTT: MQTT client closed
2021-11-01 12:55:28.666 INFO MQTT: MQTT client reconnecting
2021-11-01 12:55:28.669 INFO MQTT: connect ECONNREFUSED 127.0.0.1:1883
2021-11-01 12:55:28.679 INFO MQTT: MQTT client closed
2021-11-01 12:55:29.285 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771329284, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:29.285 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.93 => 122.91
2021-11-01 12:55:29.349 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771329349, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:29.350 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:29.379 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771329379, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:29.380 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:29.471 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771329471, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:29.472 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:29.500 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771329500, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:29.500 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:29.565 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771329564, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:29.565 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:29.666 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771329666, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:29.667 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:29.707 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771329707, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:29.708 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:29.751 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771329751, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:29.752 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:29.776 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771329776, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:29.777 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:29.802 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771329802, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:29.803 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:29.892 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771329892, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:29.893 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:29.939 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771329938, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:29.940 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:30.020 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771330020, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:30.021 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:30.095 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771330095, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:30.096 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:30.173 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771330172, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:30.174 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:30.250 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771330249, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:30.250 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:30.339 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771330339, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:30.340 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:30.386 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771330386, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:30.387 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:30.468 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771330467, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:30.468 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:30.565 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771330565, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:30.566 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:30.591 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771330591, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:30.592 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:30.618 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771330617, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:30.618 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:30.787 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771330787, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:30.788 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:30.857 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771330856, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:30.858 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:30.936 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771330935, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:30.937 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:31.088 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771331088, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:31.089 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:31.114 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771331114, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:31.115 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:31.161 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771331161, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:31.162 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:31.331 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771331331, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:31.332 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:31.415 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771331414, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:31.415 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:31.480 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66561: { time: 1635771331479, value: 122.91 } with options { qos: 1, retain: true }
2021-11-01 12:55:31.480 INFO ZWAVE: Node 10: value updated: 50-0-value-66561 122.91 => 122.91
2021-11-01 12:55:31.679 INFO MQTT: MQTT client reconnecting
2021-11-01 12:55:31.684 INFO MQTT: connect ECONNREFUSED 127.0.0.1:1883
2021-11-01 12:55:31.696 INFO MQTT: MQTT client closed
2021-11-01 12:55:34.697 INFO MQTT: MQTT client reconnecting
2021-11-01 12:55:34.701 INFO MQTT: connect ECONNREFUSED 127.0.0.1:1883
2021-11-01 12:55:34.711 INFO MQTT: MQTT client closed
2021-11-01 12:55:35.215 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771335215, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:35.216 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.3 => 1.03
2021-11-01 12:55:35.297 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771335296, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:35.298 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:35.345 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771335344, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:35.346 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:35.436 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771335436, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:35.437 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:35.519 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771335519, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:35.520 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:35.548 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771335548, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:35.549 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:35.647 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771335646, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:35.648 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:35.709 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771335708, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:35.709 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:35.752 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771335752, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:35.752 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:35.824 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771335823, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:35.825 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:35.852 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771335852, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:35.853 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:35.882 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771335882, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:35.883 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:35.956 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771335956, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:35.957 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:36.016 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771336016, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:36.017 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:36.078 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771336077, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:36.079 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:36.168 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771336167, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:36.168 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:36.250 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771336250, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:36.251 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:36.295 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771336295, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:36.296 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:36.395 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771336395, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:36.396 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:36.439 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771336438, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:36.439 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:36.457 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771336456, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:36.457 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:36.485 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771336484, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:36.485 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:36.511 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771336511, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:36.512 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:36.538 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771336538, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:36.539 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:37.072 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771337072, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:37.073 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:37.132 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771337132, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:37.133 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:37.214 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771337214, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:37.215 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:37.381 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771337381, value: 1.03 } with options { qos: 1, retain: true }
2021-11-01 12:55:37.382 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.03
2021-11-01 12:55:37.712 INFO MQTT: MQTT client reconnecting
2021-11-01 12:55:37.720 INFO MQTT: connect ECONNREFUSED 127.0.0.1:1883
2021-11-01 12:55:37.727 INFO MQTT: MQTT client closed
2021-11-01 12:55:40.727 INFO MQTT: MQTT client reconnecting
2021-11-01 12:55:40.731 INFO MQTT: connect ECONNREFUSED 127.0.0.1:1883
2021-11-01 12:55:40.741 INFO MQTT: MQTT client closed
2021-11-01 12:55:40.951 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771340950, value: 1.11 } with options { qos: 1, retain: true }
2021-11-01 12:55:40.951 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.03 => 1.11
2021-11-01 12:55:41.012 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771341012, value: 111.8 } with options { qos: 1, retain: true }
2021-11-01 12:55:41.013 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 133.8 => 111.8
2021-11-01 12:55:41.166 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771341166, value: 109.2 } with options { qos: 1, retain: true }
2021-11-01 12:55:41.167 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 111.8 => 109.2
2021-11-01 12:55:41.213 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771341213, value: 109.2 } with options { qos: 1, retain: true }
2021-11-01 12:55:41.214 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 109.2 => 109.2
2021-11-01 12:55:41.307 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771341306, value: 109.2 } with options { qos: 1, retain: true }
2021-11-01 12:55:41.308 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 109.2 => 109.2
2021-11-01 12:55:41.388 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771341388, value: 109.2 } with options { qos: 1, retain: true }
2021-11-01 12:55:41.389 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 109.2 => 109.2
2021-11-01 12:55:41.452 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771341452, value: 109.2 } with options { qos: 1, retain: true }
2021-11-01 12:55:41.452 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 109.2 => 109.2
2021-11-01 12:55:41.551 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771341551, value: 109.2 } with options { qos: 1, retain: true }
2021-11-01 12:55:41.552 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 109.2 => 109.2
2021-11-01 12:55:41.640 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771341640, value: 109.2 } with options { qos: 1, retain: true }
2021-11-01 12:55:41.641 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 109.2 => 109.2
2021-11-01 12:55:41.694 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66049: { time: 1635771341694, value: 109.2 } with options { qos: 1, retain: true }
2021-11-01 12:55:41.695 INFO ZWAVE: Node 10: value updated: 50-0-value-66049 109.2 => 109.2
2021-11-01 12:55:41.776 DEBUG MQTT: Publishing to zwave/nodeID_10/50/0/value/66817: { time: 1635771341776, value: 1.28 } with options { qos: 1, retain: true }
2021-11-01 12:55:41.777 INFO ZWAVE: Node 10: value updated: 50-0-value-66817 1.11 => 1.28
2021-11-01 12:55:43.743 INFO MQTT: MQTT client reconnecting
2021-11-01 12:55:43.747 INFO MQTT: connect ECONNREFUSED 127.0.0.1:1883
2021-11-01 12:55:43.757 INFO MQTT: MQTT client closed
2021-11-01 12:55:46.758 INFO MQTT: MQTT client reconnecting
2021-11-01 12:55:46.762 INFO MQTT: connect ECONNREFUSED 127.0.0.1:1883
2021-11-01 12:55:46.772 INFO MQTT: MQTT client closed
2021-11-01 12:55:49.773 INFO MQTT: MQTT client reconnecting
2021-11-01 12:55:49.777 INFO MQTT: connect ECONNREFUSED 127.0.0.1:1883
2021-11-01 12:55:49.787 INFO MQTT: MQTT client closed
