how to slowly dim lights?
Use the transition option in the light.turn_on
service
https://www.home-assistant.io/integrations/light/#service-lightturn_on
This is great for scripting, however, I’m hoping to find a way to get the Google Assistant Integration to smooth the transition for verbally requested changes to brightness and color. I have a feeling this isn’t possible and actually is being taken care of on the Lifx Cloud side.
Google Assistant (Cloud) to Lifx Cloud is trash, so I’m staying on HA regardless lol.
Write a script and call it from your voice assistant.
like this? in configuration.yaml
alias: slaap langzaam uit
sequence:
- service: light.turn_off
domain: light
entity_id: light.lampen_slaapkamer
brightness: 0
transition: 18
Like this:
sequence:
brightness: 0
transition: 18
Component error: alias - Integration ‘alias’ not found.
Component error: sequence - Integration ‘sequence’ not found.
Like this:
- alias: slaap langzaam uit
sequence:
brightness: 0
transition: 18
were to put it?
It’s a script. So…
Under script:
in your configuration.yaml file or if your configuration.yaml file contains this:
script: !include scripts.yaml
then it goes in the scripts.yaml file (do not put the line scripts:
in this file).
Or you can use the GUI to create it.
Incorrect type. Expected “object”.
if i put it in the scripts.yaml
in the UI
Actually I had it right the first time. Scripts are a dictionary not a list, but like this:
slaap_langzaam_uit:
sequence:
- alias: 'slaap langzaam uit'
brightness: 0
transition: 18
now i get this
Visuele editor wordt niet ondersteund voor deze configuratie:
- Sleutel “alias” wordt niet verwacht of ondersteund door de visuele editor.
Je kan nog steeds de configuratie in YAML bewerken.
Ok so the editor does not support an alias. You need an alias to be able to call the script from your voice assistant. You have two options:
Just use the YAML mode of the editor.
Delete the
alias
from the script and use customize to give your script afriendly_name
now i get this error
Message malformed: extra keys not allowed @ data[‘sequence’][0][‘customize’]
sequence:
- customize: slaap langzaam uit
brightness: 0
transition: 60
mode: single
Please read the customize link I posted. It does not go there.
Tom, I know all about calling scripts from GA, what I wasn’t clear in my description about I guess is the fact I want non scripted commands for percentage and color change to have this transition. I don’t think writing a 100 scripts plus ones for color changes is a viable answer.
I believe lifx cloud must have a global change transition variable that smooths all voice assistant commands. Trying to see if there is a way to pass GA percentage or color variables to a script within HA for a change.
Btw, in your script code the reason alias isn’t working is indentation and the ‘-’ . Here is an example of a working script for calling a custom lifx cloud scene:
alias: It's Movie Time
sequence:
- service: scene.turn_on
entity_id: scene.movie_time
mode: restart
