I try to install my newly received and configured SMLIGHT SLZB-06 adapter with a fresh setup of zigbee2mqtt in my Home Assistant via LAN.
SLZB-06 is on and configured with Firmware 0.9.9 (Mar 3 2023)
Home Assistant is Version 2024.1.2
zigbee2mqtt add-on is Version 1.35.1-1
my config is
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
server: mqtt://localhost:1883
user: mqtt
password: i...............?
serial:
serial:
port: tcp://zigbee.fritz.box:6638
baudrate: 115200
disable_led: false
advanced:
transmit_power: 20
I am receiving following error while starting the add-on in Home Assistant:
[12:36:27] INFO: Preparing to start...
[12:36:28] INFO: Socat not enabled
[12:36:28] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2024-01-08 12:36:30: Logging to console and directory: '/config/zigbee2mqtt/log/2024-01-08.12-36-30' filename: log.txt
Zigbee2MQTT:info 2024-01-08 12:36:30: Starting Zigbee2MQTT version 1.35.1 (commit #unknown)
Zigbee2MQTT:info 2024-01-08 12:36:30: Starting zigbee-herdsman (0.30.0)
Zigbee2MQTT:error 2024-01-08 12:36:30: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-01-08 12:36:30: Failed to start zigbee
Zigbee2MQTT:error 2024-01-08 12:36:30: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-01-08 12:36:30: Exiting...
Zigbee2MQTT:error 2024-01-08 12:36:30: Error: spawn udevadm ENOENT
at Process.ChildProcess._handle.onexit (node:internal/child_process:284:19)
at onErrorNT (node:internal/child_process:477:16)
at processTicksAndRejections (node:internal/process/task_queues:82:21)
Any idea I can approach for a resolution?
