SLZB-06P7 can't get to work with Zigbee2MQTT
I followed tutorials to the letter but can’t get the SLZ-06P7 to start Zigbee2MQTT…
Copied the ieee and it is connected to my network
I got the following in my log
Starting Zigbee2MQTT without watchdog.
[2024-09-10 09:37:37] error: z2m: Error while starting zigbee-herdsman
[2024-09-10 09:37:37] error: z2m: Failed to start zigbee
[2024-09-10 09:37:37] error: z2m: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
[2024-09-10 09:37:37] error: z2m: Exiting…
[2024-09-10 09:37:37] error: z2m: Error: network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby (Error: AREQ - ZDO - stateChangeInd after 60000ms
at Object.start (/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:59:23)
at ZnpAdapterManager.beginCommissioning (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:365:31)
at processTicksAndRejections (node:internal/process/task_queues:95:5)
at ZnpAdapterManager.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:86:21)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:138:29)
at Zigbee.start (/app/lib/zigbee.ts:64:27)
at Controller.start (/app/lib/controller.ts:140:27)
at start (/app/index.js:154:5))
at ZnpAdapterManager.beginCommissioning (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:367:23)
see here: CC2652RB Error Network Commissioning Timeout (panID or extendedPanID already exists nearby) · Issue #10858 · Koenkk/zigbee2mqtt · GitHub
Found your information but did not work
advanced:
pan_id: GENERATE
ext_pan_id: [0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08]
network_key: GENERATE
but IS working with:
advanced:
pan_id: GENERATE
ext_pan_id: GENERATE
