Recently I have this error in logs during HA startup.
I don’t have any slzb-07 at home, I only have couple slzb-06 units an they both not even connected to HA. They are connected to their respective Zegbee2mqtt containers.
How can I know which component is responsible for this error and remove it?
2024-09-05 14:39:50.326 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
File "/usr/local/lib/python3.12/site-packages/aiohttp/resolver.py", line 104, in resolve
resp = await self._resolver.getaddrinfo(
aiodns.error.DNSError: (4, 'Domain name not found')
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1301, in _create_direct_connection
hosts = await self._resolve_host(host, port, traces=traces)
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 911, in _resolve_host
return await asyncio.shield(resolved_host_task)
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 948, in _resolve_host_with_throttle
addrs = await self._resolver.resolve(host, port, family=self._family)
File "/usr/local/lib/python3.12/site-packages/aiohttp/resolver.py", line 113, in resolve
raise OSError(msg) from exc
OSError: Domain name not found
File "/usr/src/homeassistant/homeassistant/helpers/discovery_flow.py", line 108, in _async_start
await gather_with_limited_concurrency(FLOW_INIT_LIMIT, *init_coros)
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 114, in gather_with_limited_concurrency
return await gather(
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 112, in sem_task
return await task
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1296, in async_init
flow, result = await self._async_init(flow_id, handler, context, data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1331, in _async_init
result = await self._async_handle_step(flow, flow.init_step, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 516, in _async_handle_step
result: _FlowResultT = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/smlight/config_flow.py", line 97, in async_step_zeroconf
info = await self.client.get_info()
File "/usr/local/lib/python3.12/site-packages/pysmlight/web.py", line 243, in get_info
res = await self.get(params=None, url=self.info_url)
File "/usr/local/lib/python3.12/site-packages/pysmlight/web.py", line 100, in get
async with self.session.get(
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 1353, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 657, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 564, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 975, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1307, in _create_direct_connection
raise ClientConnectorError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host slzb-7.local:80 ssl:default [None]
