with SMA integration (SMA Solar - Home Assistant) it is possible to access different SMA devices. What I have not managed so far is to access the SMA Home Manger 2.0. Are there any solutions for this?
Frank
Have you found a solution? Would help me a lot too.
Greeting Werner
Hello Werner,
no solution so far.
Frank
Too bad. Thank you very much
Hello
No news?
Is it possible to add SMA Inverter AND home Manager 2.0 to HA.
FYI, the Inverter and the Home Manager are connected via ethernet to my router?
Hello Plouf34,
no connection to Home Manager 2.0 possible.
For SMA Inverter it is possible (new with SMA Integration [SMA Solar - Home Assistant]; old via Blue Tooth [GitHub - SBFspot/SBFspot: Yet another tool to read power production of SMA® solar/battery inverters])
Frank
