SMA integration - IP address
Hello
How to change IP addres of SMA inverter configured in SMA integration ?
My problem look like this:
I just ran into this. With the current version of Home Assistant you can just remove the entry and re-add it. Home assistant will see that you are adding the same device and continue providing data with the same entities that already existed before you made the change.
Note: when removing the device there is a message that you need to restart home assistant to complete the removal, I did not take that step but instead immediately added the device again with the new IP address.
See the screenshot below as ‘proof’.
Best regards,
Lieven.
